How important is fuel economy to you?
I haven't filled up since Christmas, so fuel economy is not high on the list. Still showing 11.4l per 100km, 25mpg diesel.
I just did a 2876km trip in Namibia. Had a grenadier trialmaster diesel. 4 adults, fully loaded with gear, and mostly on lowish (2-2.4bar), and for some parts ridiculously low tyre pressures (1 bar in the deepest sand). Mixture of high speed (70-80kph) dune driving (more like 40m height dune skidding and jumping at high speed), salt and gravel roads (between 80-140kph), deep corrugations (50-70kph), and highway driving (130-166kph). And a lot of climbing up and down gradients from sea level up to 1700m above sea level. All with a heavy right foot, and done with a DTE plug and play ECU power control module installed. Shout out to Ineos M&Z in Windhoek Namibia who made it all possible. My fuel economy for the whole trip averaged 13.6L/ 100km.
My grenadier Trialmaster diesel- at home in Australia isn’t chipped (yet), and our police won’t let me drive at 166kph, nor are Australian roads generally good enough to drive at high speed safely. I still have a lead foot though. Fuel consumption for me in Australia at highway speeds (80-100kph) is usually around 9.7L/100km or less. Average fuel economy for me in Australia which is a mixture of highway, city, and a little off road gravel is currently 11.7L/100km.
I think these are good numbers for the Grenadier, and better than I expected especially the Namibian trip fuel consumption. I have a BMW X6 which has the same diesel engine (ECU chipped too) and I get around 10.4L/100km driving that in a combined city/highway cycle with usually just 1-2 people in it.The Ineos for heavier weight, different engine and gearbox mapping, and usually with around 1000kg more weight is only using a fraction more fuel. I think that’s awesome and reflects how good Ineos have set the vehicle up.
Bottom line, I love my Grenadier, the best overlander I’ve driven in 20+ years and will not be changing it for anything else any time soon. 😎😀
I have just had the pinion seals replaced on front diff and a few other bits n pieces including the software update from 1946 to 2940. I used to have the fuel range showing >330 but now after filling up it shows >260??
No change in driving manner etc. I was averaging about 300 odd miles to a tank, certainly more than 260 even if 'greater than'.
I've been tracking my miles and fuel since I picked up my IG in January of 2024.
My last fill-up on 1/26/2025 was at 14,128 miles. My average miles between fill-ups is 176.60. My average gallons per fill-up is 16.28 at an average price of $73.20. In total I've paid $5,856.12 for fuel. 38% of those miles have been pulling a trailer. My average MPG is 10.63. My average price per gallon has been $4.55.
My average mpg without a trailer with the stock tires was 13.518.
My average mpg without a trailer with 315/70/17 tires is 11.717.
The difference in circumference between stock 265/70/17 and my 315/70/17 is 8.72%. So my "adjusted" mpg without a trailer with the 315's is 11.717 *1.0872 = 12.74 mpg. So I seem to have lost 0.778mpg due to the taller/wider tires, lift, roof rack, and bull-bar.
My best tank ever was 15.77mpg. My worst was 6.56mpg (towing a trailer over a mountain pass).
Most of this was at 91 Octane fuel. I had one tank at 87 (all the station had) and a few at 92 and 93 octane. Mileage didn't seem to materially change based on octane rating).
That’s interesting, mine has just gone the other way.
No software update though.
Mine at full used to always show >460km.
This month it all of a sudden now shows >600km.
Maybe it’s just learning and took 15,000km to get there.
There’s a lot of criticism on Pistonheads re the Grenadier fuel economy, i suspect this will pop up in many of the upcoming reviews too. So how important is it?
For me it doesn’t make that much difference, not because I am filthy rich or own a refinery, but because for what I am going to do with the grenadier it won’t make much difference To the amount of fuel I’ll use.
Yes we’d all like a vehicle that can tow 3.5 ton at motorway speeds and get 50MPG but it doesn’t exist. What I have found is that once you load a vehicle up, especially with a trailer, physics takes over. There’s a certain amount of energy required to move a certain weight over a certain distance. So while the 2.2 TD I defender I had last was possibly better on fuel than my first 2.8 defender on a school run once you put a trailer behind it there was little difference. In fact the extra torque of a larger engine means you can run a higher gear.. I’ll bet if you towed 3.5 ton with a modern hybrid city car you’d find it did less than 15MPG.
Towing a 2.5 ton digger around will level up the fuel economy on most cars, there’ll be little difference between a 2.0l and a 3.0l its just physics. It will just be a nicer experience in the 3.0l.
I came from a 200 series LC, On my best day I would average 10-11 MPG. MPG's do not matter to me either...as its a well built heavy duty vehicle.
