High beam connection for lightbar
2:50 AM
For those interested in triggering a relay from the high-beam headlight circuit, the high-beam wiring is VIOLET/ORANGE on the back of the headlights. My LP4's in the grill which replaced the stock aux. lights are now linked with the high-beam circuit. Super easy to flick on/off on rural roads. See attached.
Sorry, but T-Taps and scotch locks are a nightmare for external, under the bonnet/hood or for any wiring. They are the best way to cut strands and introduce green death (green corrosion) into the centre of a wire especially in highly corrosive environments like beach driving. There are more reliable splicing and joint sealing methods that will not give grief six months down the track.
anand
11:50 AM
Maryland
Seconding this... I'm 99% sure the connector is a generic 6 pin DT style, so I ordered a pair of pigtails and am just going to do a T-Harness; where 5 pins go straight through and the 6th (high/main beam) has a Y so I can run it to my SwitchPros
n3qem
11:50 AM
USA
should have pointed out that was a temp install until I could fabricate a waterproof Y. I knew someone would comment....
8:50 AM
Pasadena, CA, USA
I’m doing this install right now. Would you happen to have a link to the correct DT connector? I want to run the low beam off off Aux 1 and then trigger the high beam with the IG’s regular high beam.
anand
11:50 AM
Maryland
This is what I ordered, however, I have not confirmed fitment yet
8:50 AM
Pasadena, CA, USA
I just did the wiring today and can confirm that the DT connector you linked works. I built a high/low lockout harness using two 5 pin relays. The low beams are triggered with Ext1 and the high beams are triggered with the high beam signal taken off of the headlight connector (violet/orange) using a Y harness built with two 6 pin DT connectors. None of this is difficult but making and testing the lockout harness is time consuming. I would suggest just buying the Baja Designs upfitter lockout harness and making your own headlight Y harness.
Happy to provide the design of the lockout harness if anyone wants to built their own.
terdrocket
11:50 AM
N. Florida
This Violet/Orange wire is a ground trigger, correct?
