Frontrunner Ineos Grenadier Storage System
I'm installing mine as we speak. It was in stock at Frontrunner a week or so ago. Quality components, well packed, but a nightmare to assemble. It comes with tons of bolts and nuts and other little parts. Had to print the manual (20 pages) to be able to identify each component (listed in mm). It looks very simple from the pictures, but more complicated to put together than Davinci's code. Also no videos around on the assembly. Product itself 5 stars, assembly 1 star and that's being generous.
Would you have any photos of it installed? Do you think it would work as a sleeping platform with the seats laid flat? thanks! George
I've completed the assembly last night, will mount it in the truck today/ tomorrow and will post pics. You might be able to use it as a sleeping platform but it wont be flush with the back seats (more like a recliner). Also you'll have to put a stronger base on it. The carpeted MDF panels that comes with are not solid enough.
I had the same thought, and there is a Black Friday sale going on so I almost bought one. However on the product pages it says the max weight it holds is 176 pounds. That means even just me and some gear may put it over the limit.
Final product... clean look, feels steady, but definitely not for sleeping. Would not buy it again, due to the major pain of assembly (looks like nothing when installed). But unless you make your own from scratch, this is a good, cheap option.
Not for sleeping because surface isn't flat when rear seats are folded?
That's one, but also the carpeted plywood is not strong enough (pretty thin). You could put a more solid one on top of it (the frame is aluminum), but this it wasn't design for sleeping. You would be more comfortable sleeping in the driver's seat. It's great if you use their Wolf Pack Pro storage crates (fits 4 of them and you still have the top). That's what I got it for.
Can the Wolf Packs by themselves support body weight?
they could depending on the weight and what you put on top of them to achieve even distribution.
This might work as a sleeper (out of Europe, and more expensive)
I looked at this, and emailed, unfortunately not suitable for sleeping due to the lengths of the boards! They can offer custom ones however!
Thought someone would have released a simple sleeping platform by now like the front runner one
There are, if you completely remove your back seats...
