Fieldmaster Half height cargo barrier must come with loadspace divider?
Beormund
3:39 AM
Kent, UK
Since finalising my fieldmaster order with my local agent (added half height cargo barrier and roof cross bars) the configurator seems to have changed so that you can no longer select the half height cargo barrier without also having the full height loadspace divider. Is that correct? Why would that be the case?
It seems same in my country but I guess dealer should be able to order that separated for you. But I just guess. Not sure.
I saw the same behavior but if you keep clicking on the individual items you can also tick the loadspace divider alone or actually remove it…
I'm not able to uncheck the loadspace divider whilst the half height cargo barrier is selected.
