Joking aside, this is indeed a huge current. With new batteries OK, but once your battery get's older this could mean a sudden death!
Seems very high current for just an electric fan. Is there an electric water pump also operating? Can the current draw be confirmed with a shunt or an amp clamp type multimeter?
Any chance you can add some context and or detail to that ?
On it's own that picture is just pure sensationalism and makes no sense whatsoever.
Normal apparently. Same as an X5 I am told. For me it doesn't happen all the time, just every now and then. I have driven around 1500km and it has happened 2 timesAnyone here who thinks that this is an adequate cooling sound?
The cooling fans will be operated by the engine ECU and will rely on multiple temperature sensor inputs from the engine and other components to determine fan on or off modes. The air conditioning refrigerant may be low from a leak. Have the a/c checked at the dealer.Ok, adding the behaviour of my funny car with regards to noisy cooling fans. Looks like it somehow is linked to some outside temp. measurements and wrong interpretation of it (mainly sw-problem ?)
-not heard/read of this specific behaviour before and curious if anybody else experiencing the same-
Situation A: outside temp between like 10-20°C, no noisy fans, AC working just as expected
Situation B: outside temp between like 22-30°C, no AC! + fans making some crazy noise while driving (center fan on max rotation + front right fan)
If I try to switch on AC in situation B, LED indicates it is on (AUTO will not work) and when I increase internal blower speed, I get some really hot air
to my face or my feet or both (depending on what I choose). And by hot air I'm not talking about outside temp., I talk like 50°C!
When I stop the car, main fan stops within seconds, front right fans continuing for 25-30 seconds before stopping as well.
Disconnecting battery does not solve the problem and car has shown Situation A and Situation B multiple times since I picked up the car 10 days ago.
Any ideas ? Very welcome.
A/C works just fine (cooling down quickly) as soon as the outside temp. is below a specific value + A/C working or not working is clearly linked to the behaviour of the fans or vice versa. Dealer is informed and will check at next visit.The cooling fans will be operated by the engine ECU and will rely on multiple temperature sensor inputs from the engine and other components to determine fan on or off modes. The air conditioning refrigerant may be low from a leak. Have the a/c checked at the dealer.
It might not only be the cooling fan but the heating of the cat to burn the ashes that draws the current. Or am I wrong with this assumption?Seems very high current for just an electric fan. Is there an electric water pump also operating? Can the current draw be confirmed with a shunt or an amp clamp type multimeter?
tower: come in foxtrot alpha romeo tango, you're clear for takeoff...Anyone here who thinks that this is an adequate cooling sound?
You think so? I got the context without much effort.
From your explanations it is a very common fault we have in northern Australia during summer 35°C to 45°C. A/C good in the morning then bad by midday. It generally ends with low gas or the condensor being blocked or having restricted cooling flow. The A/C is an input to the ECU that controls the engine electric fans in most integrated a/c systems after that the a/c low and high pressure switches will also assist in controlling a switched fan.A/C works just fine (cooling down quickly) as soon as the outside temp. is below a specific value + A/C working or not working is clearly linked to the behaviour of the fans or vice versa. Dealer is informed and will check at next visit.
Just curious if others experienced a similar behaviour.
Thanks a ton for the explanation, will take that info to the dealer.From your explanations it is a very common fault we have in northern Australia during summer 35°C to 45°C. A/C good in the morning then bad by midday. It generally ends with low gas or the condensor being blocked or having restricted cooling flow. The A/C is an input to the ECU that controls the engine electric fans in most integrated a/c systems after that the a/c low and high pressure switches will also assist in controlling a switched fan.
Late to the game on this one but is that the draw of the coolant system at rest?
. . . same here.I lost c. 10% battery SOC whilst the DPF regen ran once I parked up.
The saga is covered in full here:@DCPU just saw your post 45, about this being a short low speed drive, any chance you can have a look at the fuse rating for the engine fans?
