- Local time
- 2:49 PM
- Joined
- Jul 27, 2022
- Messages
- 6,005
But entirely consistent with the fuse arrangement and cabling indicated above.
Yes perhaps for one, but we have at least two if you include the one in the right hand bumper wing; and of course other things could also be drawing power as per your water pump suggestion.Seems very high current for just an electric fan.
I believe it to be operated off the front belt.Is there an electric water pump also operating?
I'm wondering if your "conniption" at the outset of your journey, i e. the transient limp mode might have been the result of a sensor glitch which had mistakenly signalled a clogged DPF.Mine just did this this morning and this is what it did to the battery voltageView attachment 7829579
Have to say I have been getting more and new error messages since the fan episode. Several times today it has been telling me to select drive, neutral or reverse, while I have been driving happily along.I'm wondering if your "conniption" at the outset of your journey, i e. the transient limp mode might have been the result of a sensor glitch which had mistakenly signalled a clogged DPF.
In the first couple of weeks of ownership the fans in mine inexplicably roared on several occasions as per your experience this morning. However it has since settled down and occurred only once in the last 6000 km.( a short 6km trip from a cold start to the local Ineos dealer two weeks ago it occured on arrival. The tech grinned and assured me that it was not uncommon!)
Hope yr adventure is going well![]()
It also happened to me in the station, the car made a lot of noise when it was stationary, like a street sweeper.As the cooling sound happened two times within the last 6400 km I think it is not a real problem. But of course my opinion would change immediately as soon as I try to sneak into a hunting area just to realise that my car wants to camouflage as a starting F-16…
Anyway the � and roe deers probably would hear my „sneaking“ anyway �
DenisM, that is exactly what happened to mine. During the first week the fans went like a hovercraft. Now i have nearly 4000km it rarely happens. Maybe only once.I'm wondering if your "conniption" at the outset of your journey, i e. the transient limp mode might have been the result of a sensor glitch which had mistakenly signalled a clogged DPF.
Best would be to give it a 10...15min drive at high load & high rpm, as has been suggested here at several occasions. This will quickly & cleanly finish the regeneration cycle and give the least diesel contamiation in engine oil.Are you better off keeping engine running when it’s happening or just lock up, walk away and leave it do it’s thing?
Ok, that’s sound advice. Appreciate itBest would be to give it a 10...15min drive at high load & high rpm, as has been suggested here at several occasions. This will quickly & cleanly finish the regeneration cycle and give the least diesel contamiation in engine oil.
I have the diesel. It was 35 deg the other day and my fan kicked in once I parked up. 1st time I heard it since owning the vehicle. Pretty loud though but didn't worry me much. Got a few looks from others in the park probably wondering why the car was left onThis
I agree it happened to me too - i suppose the car does not know when you will stop - DPF burn creates lots of heat ( and smell when new ) so i suppose the fan is used to vent under the car but a bit disconcerting when it happens for the first time when you have stoppedIt‘s a feature, not a bug
Most likely just the DPF regenerating. For that it needs quite a high temperature on the exhaust side. When the vehicle is shutdown during the process, the fan will run for few minutes after engine shutdown to cool everything off.
