Australasia Electric Side Steps
Kev
1:46 AM
Brisbane QLD, Australia
I didn't want to use the drain so I used a grommet in the rearseat floor closer to the door. The wires then come out closer to the motor and closer to the sill under for more protection. If you have the LED version install the steps with the cable to the rear (note: the endplate is removeable and there is more cable inside that can be pulled out for an exact length). I used the rearseat earth and power from under the rearseat so only the CANBUS cable had to go forward :)
Great thanks for that, it was my plan so thanks for confirming this, I meant grommet not the drain hole sorry. I didn’t get the LED version, I bought the embossed GRENADIER version, they look fantastic. Does the LED look good?
Chook
1:46 AM
The video does show them using the rear seat drain hole but the grommet near the door is better. Yep the lights are great all programmable. My main plan for the LED was for ambient lighting at campsite but they are helpful (and fun). I will be at the BNE Xmas party if you want to see them on the 30th Nov
Reactions: Kev
Kev
1:46 AM
Yes I saw the Xmas party was on, just a busy time of the year but I am hoping to make it.
