Eibach Pro-Lift Kit ~ +30mm coil springs
anand
12:18 PM
Maryland
The only options online are 2.5" front 1.2" rear or 1.7" front 1.2" rear....
The 500lb rear springs are in testing and it has been posted they will be available in coming weeks with the 1000lb'ers after that; as are their remote resi shocks
PDX_Keith
9:18 AM
Portland, OR, USA
New owner here trying to learn. I did some searching but I do not specifically see maximum spring length with OEM shocks discussed. How much of a lift can the stock shocks handle without becoming the limiting factor on suspension drop and thus harshly using the shock as a limiter. I've broken Bilstein's on my 4Runner due to that. Thanks!
[ Adam ]
12:18 PM
Fairfax, VA, USA
My interpretation of the current state of affairs is that anything beyond 30mm seems to risk damaging the cv boot on the front driveshaft.
The only resolution seems to be replacement of the driveshaft with an aftermarket, which increases NVH. I'm not interested in that and have been happy with off-road performance thus far.
I'll be installing @Metalcloak front swaybat disconnects as soon as they get them to me, I expect these will have more impact to off road performance than any lift on stock shocks.
3:48 AM
South Australia
SOLD!!! Fantastic thanks Steve. Hopefully (for me) they fit the heavier springs but.. seems a bit of a lottery. My fingers are X'd... thank you again. cheers Paul
Hi Paul,
I did get the HD factory front and rear springs, and removed them on day 1, sorry I forgot about this thread, probably caused by all the excitement of the new vehicle etc.
They are sitting in a box in my shed, you can have them for free if you want to pick them up.
Cheers,
Steve.
MrMike
1:18 AM
Portal axles are now available from IA, no worries at all now! Cost....remains to be seen, but I'd say they are expensive.
anand
12:18 PM
Maryland
It's the same kit LeTech has offered since last year (y)
Tom109
12:18 PM
I like this. Harkening back the the early coil-spring LR days of suspension mods. Maybe a droop kit is in order to minimize time the CV spends overextended?
Regarding sway bars, I fully plan to test daily driving with them removed.
