bikesandguitars
The shop that did mine called Ineos and got the alignment specs direct from them.I just installed the 2.5" Eibach springs over this past weekend. I agree with the above, the ride is better with the new springs. It is noticeably stiffer but handles and rides better. Steering is improved as well. I have not yet changed the tires. I will move up to 34s, but still researching it. Of note, I haven't found anyone besides the dealer who has the Grenadier alignment software in their system, so I will have to take it back to the dealership 200+ miles away to get the alignment checked. It doesn't seem to need alignment as it drives straight even at 90 mph, but I have always checked alignment after a lift.
For anyone planning to do it yourself, a few tips. It should go without saying, but you do need a lift and jack stands. The front brake calipers will have to be taken off to get enough movement in the brake lines. The rear ones you can get enough play with loosening the line attachments to the axle. Control arms, sway bar linkages, shocks in the front and rear need to be disconnected, the drag link in the front needs to be disconnected as well. With this the axle will drop enough to get the springs out and easily put the new ones in. We needed a little extra movement in the front control arms to get them reconnected so we used the alignment adjustments to do so. We marked them ahead of time so we could adjust them back to the pre-disassembly position. We did not need to do this in the rear. One more note that might not be self explanatory, to orient the springs correctly, the writing on them should be right side up. I hope this helps as I have not seen any posting on this as a DYI.
