Eibach 2.5 Lift Kit w/ 34x10.5x17” BFG KO2 Installed!
I finally installed the new, one-size-fits-all, Eibach 2.5 spring kit and 34x10.5x17 BFG KO2’s. The change in ride height is substantial. The front end level is very noticeable (with winch). While I only have 40 -50 miles under my belt, I believe the ride is slightly improved. Strangely, the cabin noise level also seems lower. But I don’t have an explanation as to why.
I decided against 35’s as I watched YouTuber Ronny Dahl show his 35’s rubbing against the wheel well at full articulation. Honestly, it was a small compromise. I feel that I’m good-to-go for the trails I like to run. The most immediate difference is the ride height and entering / exiting the vehicle. I’m 6’2 and I’m about at my limit for throwing a leg up to climb in. I may have to install a bolt-on step for around town driving.
This looks very good!
Fuel economy difference? Shorter range?
2,5" EIBACH Lift kit + KONI Heavy Raid and 305/70 R17 Yokohama Geolandar Tires on the Black Rhino Arsenal Rims with ET38
I have about 4000mi on Eibach 2.5’s with 34-35” tires. I have to say the ride was terrible. Ok, the ride was great at sub 55mph but anything above was frightening at first. I got used to it but it always irritated to death and honestly is very unsafe on the wrong roads.
I set caster and am running the Fox ATS stabilizer. Ran the stock stabilizer and ran without one at all for a time. The stock stabilizer makes for a busy drive as it tends to not self center well being overly stiff. The FOX ATS makes all the difference.
Now, even then the truck is still a pain in the a$$ to drive at higher speeds for any amount of time. If you ever have to emergency brake then your really in for a ride.
All that said, I just installed the King shock set and wow, the truck drives like a champ now. When I removed the stock shocks I noted that they have the least amount of dampening I have ever encountered on a truck in the class. Pokeing fun at Ineos, I wonder if they screwed up the specs between the steering stabilizer and the main shocks 😂.
I still only have a few miles on the Kings, but set about midway on adjustment the truck is more planted, more nimble and vastly safer in my experience.
Of course I went Kings, but Konis or some other adjustable shock will do about the same. Bottom line, ditch the stock steering stabilizer and grab some shocks with a bit more dampening and you won’t regret it. I would suggest this for a bone stock truck as well FYI.
Of course I went Kings, but Konis or some other adjustable shock will do about the same. Bottom line, ditch the stock steering stabilizer and grab some shocks more a bit more dampening and you won’t regret it. I would suggest this for a bone stock truck as well FYI.
Are the kings factory length, or did they make them longer?
Thanks @Dokatd, are your Kings prototypes or are they now available to the masses? I preordered from Owl on August 14th.
Thanks.
I got mine from Owl Outdoors. They are kinda readily available. 6-8wks if you have to wait for a new batch. They are available from a few places so you might shop around till you find someone that has a left over set. Otherwise I do think an adjustable Koni is a good alternative and much cheaper.
Do you know if the Koni is stock length or a bit longer?
I do not. I’m sure you can find a Koni Part number that would gain you a bit. But you want as much up travel as you can get not down travel. So unless you’re modding your suspension a ton, a bit more length probably won’t do you any good.
Looks great, I love that set up. Here’s mine w/US spec 2.5 Eibach springs running 295 18 BFG KO2. No rubbing at all
