Does TDI not sell to the worlds 5th largest economy?
Dual Grenny Guy
10:26 PM
Louisiana, USA
If you are looking for max fuel economy set it to Level 1. One of my customers is getting 19MPG hand calculated on long drives in Florida at Level 1. I pair this or the Agile tuner and sell with the IO Pedal tuner. I see a huge difference when paired with our Kooks Exhaust system given it has less back flow. If you are interested in the IO Pedal tuner, I have those too and sold 3 this week. 704-682-9323 Thanks, David I do have to finish editing more videos of this as well for our YouTube channel.
I enjoy seeing vendors post on the forum, many do. Probably next month you will get an order for a Kooks exhaust set up from an old timer in Louisiana. 👍🙏
Michael_in_Baja
8:26 PM
Baja California Sur, Mexico
ORSO
5:26 AM
Italy
you made me curious and I sent an email for some clarifications.
since someone seems to have already mounted it I ask you my doubts:
- is the box waterproof? it must be inside the engine which is not exactly the cleanest place for an electronic component.
- when you take the car for a service with the relative software update do you have to physically disconnect everything?
- do you have a couple of photos of the finished work? where are the connectors positioned?
- do you notice the difference compared to the original mapping?
thanks
11:26 PM
Maryland, USA
All the while our governor has one of the largest carbon footprints on the planet. He loves taking a helicopter and here there and everywhere.
:ROFLMAO: Don't you know its do as I say, not as I do. Same applies for all of the Globalist Agenda 'leaders'. Gates, Kerry, etc, etc, etc..
David Czarnecki
Supporting Vendor
11:26 PM
Statesville, NC, USA
Looking forward to it. If there is anything else you are looking for keep us in mind. I have to get our website fully loaded with our other partners products we furnish as well.
David Czarnecki
Supporting Vendor
11:26 PM
thanks
The TDI Tuner and the Agile Offroad tuner both are appear to be water proof. The both mount in front of the brake booster area, basically on the left (driver's side) inside fender. Where you find the electrical outputs to connect EXT1 at for example. The portions that plug into the boost sensors and cam phaser (rpm) are reappy well done on both and are very similar to OEM. The directions on the Agile site for installation insttructions show pictures. Either can be installed with no tools which is cool. I would recommend that you remove before taking to the dealer which is a 5 minute task. The performance is significently improved especially with our Kooks Cat Back exhuast. I have some video.
View: https://youtu.be/fR8HQHF_1_Y?si=Va03ts-p6oUHjHuj
Dual Grenny Guy
10:26 PM
Louisiana, USA
Can you please post that video when all the testing is done and you explain the difference between the tunes? Really interested in the outcome. Thanks..🙏
Michael_in_Baja
8:26 PM
thanks
I will reporr on my experience when mine arrives, maybe others can answer these questions sooner.
From what I have seen the box is waterproof and quite robust. As far as disconnecting it. As I undestand it there are three plugs and all easily accessed.
