- Local time
- 2:38 PM
- Joined
- Jul 27, 2022
- Messages
- 6,005
- Reaction score
- 13,325
It's being rewritten to suggest you find an easier route...What does the Manual say to do?
I too am wondering of the softer terrain would allow the system to detect wheel slip and confirm lock.Take it offroad and try again.
100% agreed .I too am wondering of the softer terrain would allow the system to detect wheel slip and confirm lock.
This all seems rather odd. In the G-Wagen, which also uses Eaton E lockers, you just smash each of the locker buttons in order as quick as you like - centre - rear - front, and they just lock in that order. No significant delays unless you have some differential wheel speed across the axles.Yes.
What are you supposed to do if you encounter a condition in front of you were you want both diffs locked? Drive through part of it with just the rear diff locking, then locked and then press the front diff button, for it to go through a locking and then locked cycle. By that time you may already be stuck, and it's certainly more of a distraction exactly when your focus should be just on driving.
G wagen is 2- 2.5x the price...This all seems rather odd. In the G-Wagen, which also uses Eaton E lockers, you just smash each of the locker buttons in order as quick as you like - centre - rear - front, and they just lock in that order. No significant delays unless you have some differential wheel speed across the axles.
I would have expected the Grenadier to operate much the same way with the exception of the mechanical centre diff lock.
Here's a thought:100% agreed .
When I tried on a soft slope some weeks ago the locker’s worked fine and fast!
But anyway you might want to activate them before you hit a difficult obstacle.
At this time the terrain might still be firm ground!
Don't you mean that when unlocking?I too am wondering of the softer terrain would allow the system to detect wheel slip and confirm lock.
Yes, but Ineos in their wisdom have integrated it with some form of electronic interlocking/logic with inputs from unrelated sensors.I would have expected the Grenadier to operate much the same way with the exception of the mechanical centre diff lock.
I can't think of any real-life situation where you would want the front locked and the rear unlocked! So any logic tp prevent this makes sense to me. Just wish there ws not so much electrics/electronics involved!I viewed a video where the front lockers were engaged and not the rear lockers. While powering up a hill and over some rocks the front differential broke. The owner made a point of saying it was his fault because he thought he could make the climb with just the front differential locked and not the rear which put too much unnecessary strain on the front differential trying to pull the full weight of the vehicle. I'm no expert but this may be a partial explanation as to why the Grenadier is set up this way.
Yes, semantics and starting first cup of coffee...Don't you mean that when unlocking?
If the system detects wheel slip across an axle then there's definitely no lock.
I would recommend before engaging lockers that you select off road mode.Here's a thought:
Page 88 Owner's Manual Differentials, second point down
WARNING: Locked differentials can cause instability on
high traction surfaces. This can cause an incident where
the vehicle is damaged or injury is sustained.
The Owner's manual is poorly written... it specifically mentions no locking on 'high traction surfaces' but likewise says the Electronic Stability Control must not be actively supporting the driver when switching on the diff locks.!
I don't get my vehicle for another 2-3 weeks to test my theories ;-) ... however I'm suggesting that perhaps the clue is in Bemax's experience on a "soft slope"...
The "system" won't engage UNTIL it senses the vehicle is not on a high traction surface... hence the continuous flashing yellow.
There needs to be some wheel slip, which the ESC would counter if it was operating.... but not so much wheel slip (spinning wheels) that the engagement of the diff lock will "shock" the driveline.
Can the ESC and traction control be switched off prior to switching the diff locks? ...engagement of the diff locks is supposed to automatically disable ESC and ABS. Turning them off beforehand however might improve the process... and make it easier for the "system" to detect the minimal wheel slip on loose/soft surfaces as a precondition for positive engagement....(it's late there's no test cricket on TV and I have an early start...forgive the ramblings...
Yet people cannot get it to work properly or it just isn't working in some cases. I feel for them.What I said
yeah, I had thought, before launch, that all the issues with diffs locking was around the sensor choice, ie not whether it had locked or not, but whether the indicator screen was up to date.Unfortunately this stuff is “normal” for Eaton e-lockers in my experience. I have a rear one in my current vehicle and it doesn’t engage immediately you do have to move it a bit on loose surfaces before it engages, and disengages. And INEOS has compounded this slightly by not adding the specific sensor so now has to use an ABS sensor or wheel sensor to work it out. We are just going to have to get used to looking and planning ahead. It’s hard to tell if some people have actual faults (because of the way it is set up) but most likely most of this is not actual faults, it’s just Eaton e-lockers.
The "smarts" are a safety/liability requirement, as with all other brands, at least here in the US. Effectively, with the locker engaged, ABS is useless (thus why ABS gets deactivated with the activation of the rear locker on the Grenadier, and most if not all other vehicles). This is the same reasoning why there is a hierarchy of locking (low range + center, then rear, then front).maybe ineos might remove some ‘smarts’ in an update? What’s everyone else think?
I once snapped a rear halfshaft on a track. Whipped the broken end out via the hub and limped though the rest of the track with just front wheel drive. On several occasions getting stuck on simple cross axle situations. If I could have locked the front it would have been simple to maintain traction.I can't think of any real-life situation where you would want the front locked and the rear unlocked! So any logic tp prevent this makes sense to me.
