Seems like most of the off the shelf kits are for 1/8 breathersi pulled out the one-way breather vent fitting from atop the rear diff on the weekend. it definitely can only exhaust diff casing air, thread measures: M10x1.0
i just bought 10 fittings 10x1.0 to suit 6mm hose. (minimum qty from RS components) Will sell the remaining 8 if they fit when they show up.Seems like most of the off the shelf kits are for 1/8 breathers![]()
This maybe useful to discussion.
RED WINCH Synthetic Rope: At 12m (40 ft.) of usable rope, this is largely an impracticle length (a few car lengths) in the majority of recoveries, not only for a double line pull or using a snatch block. (Adding a 30m extension does not assist, you dont winch with that end).
You keep saying this stuff but it’s not entirely true. Adding an extension absolutely does help. You may need to reset with a shorter winch rope if you need to move the vehicle a longer distance but it absolutely helps you to reach your anchor point. Saying it doesn’t assist is just silly. It’s not ideal if you are trying to winch yourself up a mountain, but many recoveries are just popping the vehicle out of a hole. We all would prefer a longer rope, but we don’t have one. It doesn’t render the winch useless.
And yes you can do a double line pull, you may just have to set it up a bit differently.
Attach extension to vehicle take extension through snatch block and connect to winch rope, winch. Easy. If you need to adjust the length of the extension you either choose an anchor point further away, or use an x-lock or similar to shorten.
Thank you.![]()
For those engaging in purchasing accoutrements for a winch accessory kit for the factory-option RED winch, make sure your pulley is able to hold the rope size (11mm from memory); most of what you'll find in the US for a 10,000-12,000 pound winch will be designed to operate with 9mm (3/8") rope.
As @AnD3rew mentioned, if your winch extension is too long, the X-Lock, or a locally preferred favorite the Recovery 8, are perfect tools to shorten the rope without diminishing its strength. And of course, if you end up having to reposition and reconfigure several times during a winch pull it isn't a "perfect" scenario, but, let's be honest, no vehicle recovery is ever perfect, if it was, there wouldn't be a recovery involved.
One big thing that we harp on over and over during our recovery classes is that while there are absolutely wrong ways, there is never only one right way in vehicle recovery
Yes but not on a thread about diff breathers...This maybe useful to discussion.
My defender rear axle and transfer case i think ended up under the rear floor - you have to wonder when you see water coming over the bonnets of old Defenders how much water gets into those vents - i dont think they are one way valves as they are supposed to vent in and out as the rear axle ( front axle , gearbox too ) heats up and then cools - I extended them much higher and fitted a standard clear automotive fuel filter on the top allowing it to breathe but not let dust inAnd
and yet no diff or transmission breathers and these ones were known to cause a problem.
OOPS I forgot - Landrover
Hi Nguni, It would be great if you show photos and let us know what products you used to extend the diff breathers. DaBullMy defender rear axle and transfer case i think ended up under the rear floor - you have to wonder when you see water coming over the bonnets of old Defenders how much water gets into those vents - i dont think they are one way valves as they are supposed to vent in and out as the rear axle ( front axle , gearbox too ) heats up and then cools - I extended them much higher and fitted a standard clear automotive fuel filter on the top allowing it to breathe but not let dust in
Not on a thread about diff breathers...
At some point it goes too far off topic. Why not start your answer on a winch thread and link back to the question here; or even start your own thread?
I've started a thread on this topic here:View attachment 7823058
This could be the transfer case breather. Front face of the transfer case up the top. Viewable from the left side of the vehicle looking up and rearwards.
Hose goes forward along the top of the transmission then up between the firewall and the back of the engine. Can't follow it to see where it terminates.
Well as the contributor of the transfer case breather info I was quite happy for DPCU to create a new thread on the topic. The forum search tool is good but a little housekeeping and structure will go a long way to keeping the info accessible. I'm sure we have all discovered hidden gems inside unrelated threads and thought 'that belongs in its own thread', but not done anything about it. I appreciate DPCU's desire to maintain some order.Are you new to Internet Forums @DCPU ?
Or are you angling for the forum policemans job ??
Maybe you feel you should be a moderator ?
Adjusting posts and opening new threads etc ...
Well as the contributor of the transfer case breather info I was quite happy for DPCU to create a new thread on the topic. <snip>
Fair question. This is my final comment on this because, ironically, this is now off-topic. You do appear determined to be offended by DPCU's actions. Your contributions elsewhere are valued and appreciated and I'm puzzled why you have chosen to dig in on this.But why ?
This thread is about Diff breathers, that's its title.
Your post was on topic, in accordance with the theme of the thread (ok it was the transfer case not the Diff - but it's the same really)
It's full of content relating to Breathers on a grenadier.
How many threads about the same subject do we need ?
Is there a competition to see how many threads one person can create ?
Do you win prizes by having your name identified as being the person who has originated more threads than anyone else ?
