Ah I see .. ve seen similar 2way valves on gearboxes and engine. I am not a mechanical engineer. So what I gonna do - ask my car mechanic. Need to talk to the guy anyway. My front camera became dysfunctional during snowfall on Saturday ..
Never really understood that design ~ go to all that effort and terminate under the bonnet with no shield or cover. Drop into a hole whilst wading and...This is what a diff breather kit looks like
Totally different to a non-return valve based breather
They are two way and allow the diff to breath out and back in from a controlled location.
I didn't design it, only posted it.Never really understood that design ~ go to all that effort and terminate under the bonnet with no shield or cover. Drop into a hole whilst wading and...
Much prefer this arrangement:
Of course any manifold introduceds a single point of failure, early Camel Trophy vehicles used to route all the separate breathers up the snorkel. Looked a little messy but where function is the absolute design criteria perhaps better.
I'd say engineers from Magna Steyr have some (limitedWhat would they know about building a tough 4WD?????
Exactly my tongue in cheek commentI'd say engineers from Magna Steyr have some (limited) experience building proper 4 wheelers as they were involved in others similar cars before (like e.g. the G-wagon). Admittedly they are not german but austrian, though
I recall my RRP38 had 4 breather tubes that terminated at a common point in the engine bay..Ric said this morning that the diffs are sealed and don't have breathers
A one way valve is pointless if there is not a second one way valve in with an opposite direction of flow somewhere.Same here DenisM. 'One-Way' valve, if the case seems unusual.
I heard for the first time in my life about these valves here, so am a complete novice. I am just wondering ... valves are never completely 100% tight, perfection only exists on paper. What if overpressure is dramatic, and underpressure isn't, and the "slow underpessure leaks" are sufficient to bring slowly everything back to normal?A one way valve is pointless if there is not a second one way valve in with an opposite direction of flow somewhere.
If it gets hot the air will go out. If it gets cold the air has to go in.
A one way valve would mean air goes out in warm conditions and under cold conditions there is just an underpressure…
Let's assume that those who build the axles know what they are doing.A one way valve is pointless if there is not a second one way valve in with an opposite direction of flow somewhere.
As my father says , that's a way to make an ass out of u and me.Let's assume that those who build the axles know what they are doing.
Irrelevant I know but you will never look at that word the same way again!
they will know for sure. But there’s still no explanation for for me how it should work only with one way valves…Let's assume that those who build the axles know what they are doing.
It may seem pointless but it's the standard setup in a number of well engineered vehicles.A one way valve is pointless if there is not a second one way valve in with an opposite direction of flow somewhere.
So you assume that the construction itself works as the inlet valve?It may seem pointless but it's the standard setup in a number of well engineered vehicles.
Axle ends aren't gas tight; and pulling air in is not really an issue. The issue is blowing oil out. Look at the design of the seal lips and how they work more in one direction than the other.
