I suspect it will have two, the engine has been optimised for torque at low revs, to get that they’d need a turbo that kicks in early, and another to give power higher up the rev band.
Both the UK and Australian price lists published before the price rise refer to the petrol engine as "turbo straight 6" and the diesel engine as "twin turbo straight six"I suspect it will have two, the engine has been optimised for torque at low revs, to get that they’d need a turbo that kicks in early, and another to give power higher up the rev band.
and audiI see Ford use the term bi-turbo for a two turbo set up.
There's no difference... the term describes two turbos in separate housings working in either parallel or in series. I've seen MB use the bi-turbo description also on the turbo V8 G-Wagenand audi
Yeah, a bit confusingI think BMWs reference to “twin power turbo” covering the turbo vanos etc etc is misleading even single turbo engines get the twin power sticker
The oil viscosities have a range starting from 0W or 5W so why should they not properly lubricate? If an engine is designed for lower viscoity than the oil in the engine, it would simply be the wrong oil. But if I am within the specs, the general claim that a higher viscosity can lead to more oil consumption than a lower one does not seem logic to me.There are a few things that can happen with higher viscosity oil in an engine designed for lower. Increased engine wear below operating temp as it can not properly lubricate leading to increased oil use. For engines with tight tolerances the high viscosity oil can’t flow into all the areas and this means it won’t seal as well. Higher viscosity doesn’t transfer heat as well and leads to higher temps….doesn’t mean don’t use increased viscosity as the application may require it and every use case is different. Time outside optimum design viscosity is important.
The above distinguishes between the twin turbo setup for the diesel and a single turbo for the petrol.This is from the brochure today. Does twin mean two or twin scroll?View attachment 7807521
The petrol and diesel are different setupsThere's no difference... the term describes two turbos in separate housings working in either parallel or in series. I've seen MB use the bi-turbo description also on the turbo V8 G-Wagen
LIQUI MOLY Top Tec 6100 0W-30
Due to the low HTHS viscosity, the motor oil may only be used in approved BMW diesel and gasoline engines.
Motor oil based on synthetic technology. Ensures outstanding performance and a long engine service life. Improves the viscosity, lowers friction and reduces fuel consumption. Additives with a much lower proportion of ash-forming substances provide optimal protection for the diesel particulate filter from dirt. Keeps sensitive engine components clean.
Approvals
ACEA C2
BMW Longlife-12 FE
LIQUI MOLY recommends this product for vehicles that needs to comply the following specifications:
BMW 83 21 2 365 935
BMW 83 21 2 405 097
BMW 83 21 2 405 666
5L Part No: 20779
20L Part No: 20772
Yep and Hi-Tec oils as well, they manufacture locally in Australia whereas LM are imported from GermanyFor us Aussies with diesels, it looks as though LiquiMoly has a product that conforms to BMW Longlife 12-FE. From imparts.com.au
maybe, for certain applications, however for the BMW engines 0W-20 (petrol) and 0/5W-30 for diesel oils are specified.Shell Rotella T6 is the best oil out there
