Although I agree to the fuel consumption I'm surprised about the rest. Wear upon cold starts I can imagine as well - though I'd assume it'd be less in normal operation temperatures.Higher viscosity can lead to increased wear, fuel and oil consumption in a modern engine developed with tight tolerances.
The Grenadier B57 engine has got a Twin Scroll Charger. This might be the reason why oil with the specification LL12 FE is the recommended, because it is more or less only a single charger.Good question.
I do know that I have seen two mentions that BMW LL-12FE (the oil referenced on the bonnet label) is not suited for engines with 2 or more turbochargers. The first is in post #9: "Not for diesel engines with 2, or 3 TC's." and the second in post #44 link from Opie Oils: "Not suitable for engines with 2 or 3 turbos."
I thought I'd read that the B57 has two turbos?
I see it the same way.will going up a viscosity grade do any harm? Because the way I see it it will prolong engine life.
There are a few things that can happen with higher viscosity oil in an engine designed for lower. Increased engine wear below operating temp as it can not properly lubricate leading to increased oil use. For engines with tight tolerances the high viscosity oil can’t flow into all the areas and this means it won’t seal as well. Higher viscosity doesn’t transfer heat as well and leads to higher temps….doesn’t mean don’t use increased viscosity as the application may require it and every use case is different. Time outside optimum design viscosity is important.Although I agree to the fuel consumption I'm surprised about the rest. Wear upon cold starts I can imagine as well - though I'd assume it'd be less in normal operation temperatures.
But can you explain why oil consumption would increase due to higher viscosity?
No it has twin sequential compound turbosThe Grenadier B57 engine has got a Twin Scroll Charger. This might be the reason why oil with the specification LL12 FE is the recommended, because it is more or less only a single charger.
There’s a dipstick on the diesel. we are just told to not use it for gauging oil levels.These oil threads are good but no-one has mentioned how often you think we should change oil drop after 1K then ever y 5K or every 10K at least we will babe draining via the sump plug as no dipstick.
The recommended oil is Petronas Syntium 0W30 DG (as listed in the Owner's Handbook). The Petronas helpline (Technical Support UK) have advised, after getting a reply from their HQ in Italy that "Syntium DG is a factory first fill product." and "Unfortunately we don't have it in our open market range."I will use in the guarantee period the recommended oil. If something happen with the engine, 100% Ineos will check which oil was used. If it’s not following their rules, they will not pay anything.
Can you share/link where you have seen this?They have bee very clear it is twin sequential for diesel
I think the vanity mirror rules apply.I am really surprised that this hasn't been mentioned anywhere or even if it is the case on the Grenadier diesel
It would surprise me if they have changed this part of the engine from standard
Yes, but if the brand is not available, it´s „recommended“, but the class is 0W30 etc and the BMW release is at the end the required one. The brand is not important.The recommended oil is Petronas Syntium 0W30 DG (as listed in the Owner's Handbook). The Petronas helpline (Technical Support UK) have advised, after getting a reply from their HQ in Italy that "Syntium DG is a factory first fill product." and "Unfortunately we don't have it in our open market range."
Where will you get oil from?
Well that's what needs clarification, several supplier's state that their oil to the specification quoted is not suitable for engines with more than one turbo.but the class is 0W30 etc and the BMW release is at the end the required one.
re q on source of turbo info:The recommended oil is Petronas Syntium 0W30 DG (as listed in the Owner's Handbook). The Petronas helpline (Technical Support UK) have advised, after getting a reply from their HQ in Italy that "Syntium DG is a factory first fill product." and "Unfortunately we don't have it in our open market range."
