Dealer update on leaking condensation from air con A/C in footwells
nodric
7:43 AM
Dallas, TX, USA
I have been documenting my woes in another thread specifically related to leaking into the car. The other issue I had raised with the dealer is condensation drips into the front footwells when using the A/C. Given I live in Hell's Kitchen (Texas) we use that a lot.
Dealer response. Many people have this issue and we have opened a case with Ineos. No known fix is available. We think they may be a retro fit part at some point.
Just writing this in case you have the issue and/or have found a way to rectify it.
Noticed the same water droplets a few days ago in our car so curious to see what the dealer fix for this will be as well.
any updates on the solution, or if they have one? And if so can you update us on what they did? Would be greatly appreciated
I'm having the same issue. I thought it was another leak in the safari roof but couldn't figure out how the water was getting there.
I have the fogging on the windshield. It’s annoying.
The work around for this is not to use the full auto setting. Set to manually only blow front facing and/or foot vents. Temperature is still basically auto though. On full auto there is always air blowing onto the windscreen which causes condensation on the outside.
TSB from Ineos
for those without Facebook, most of the TSBs are in the Resources section here on the forum:
For the drops of water in the footwell from the air con pipes on hot humid days. I was told today, there is a fix. The fix is fitting a microfilter. I’ll update at the end of the month once it’s been fitted.
This TSB seems like a fix to an adjacent problem, but not necessarily THE problem we are experiencing. The problem as I have had it explained to me, is not condensate inside the drainage pipe failing to exit the vehicle, but condensation forming on the OUTSIDE of the pipe and then dripping off on to the centre tunnel and into the footwell. My dealer yesterday said they had applied a fix to their own fleet vehicles, but until Ineos publish an official service measure they cannot do anything to properly fix customer vehicles. Twice they have tried sealant and additional foam packing fixes to my car but the problem persists, and after one "fix" even got worse. They say the proper fix is not straightforward or easy and were waiting to see what Ineos come up with short of replacing the entire HVAC heat exchanger assembly with a redesigned one.
External condensation is more than likely the issue and rarer on internal ducting. I have this raised with local agent for inspection but knowing there is no fix for it, I'll wait until I deliver it back for a fix.
I've raised a ticket directly with Ineos in the hope that it will lend weight to the fact that many owners are experiencing this and standing by waiting for them to solve it. I got a reply suggesting I "visit your dealership and have them look at it in more detail" but I responded that we are well past that stage and now need Ineos to just fix it.
Any update? I have since been advised non-fixable as the IA method is... a patch at best.
I had mine fixed about a year ago now, and it has never dripped since. I believe IA recommended the local agent to insulate a/c pipes in that footwell / console area. I live in the tropics so use A/C every day and would have noticed if It came back. Dealers locally are Pickerings in Townsville Australia if you need a reference to contact Ineos with details of a successful fix.
I
Interesting - and that was under IA warranty?
Took mine in to Mossy Houston with this problem. They say they did the drain hose TSB but I have my doubts. Anyway, the problem remains but at least it's acknowledged. How do we register our complaint directly with IA?
