Mine went in fine, I also do not have the smart alternator cable connected (I gather this is what you mean?).I just finished installing the D250SE and a couple of odd things. First connected via CTEK busbars, grounded - terminal to battery and did not hook up the charge voltage (black) nor red ignition trigger as battery is wet and it is still not clear to me the fate of the red wire (smart alternator).
Once complete I did get some warning lights as others have experienced and after short drive and a turn off/restart cycle all went out except the lower right hand exclamation sign inside the triangle-nothing popping up on the center screen. One other thing I noticed is that the Offroad screen now shows my battery charge at 100% which I have never seen before and doesn't sound right to me.
Has anyone else experienced this set of symptoms after installing or have any insight into what I might be looking at? Otherwise everything seems to be fine and I am not noticing anything when driving it.
Thanks
Exclamation sign indicates a service battery connection issue, but this is top left.
Perhaps you could post a photo of your function indicators?
