Black Sheep Inovations
How much are the factory sliders, around $1700 mild steel made in China? $2200 seems a fair price to me for Swiss made in stainless.
Add import tax and shipping to that $2200. Plus installation if you aren't handy.
And how much is the Ineos factory warranty worth?
They would be about $2600 landed inc freight, GST and broker fee.
I don't think Black Sheep are targeting the hardcore off road market, rather a more affluent style conscious buyer.
The photos do not tell about the surface of the rack, no? Can one only use the airlines on the sides to fix stuff? Weird that not a single photo shows the top in detail…
Black%20Sheep%20Innovations%20GmbH%20-%20Dachplattform%20Erweiterung%20Ineos%20Grenadier%20-%2002-min.jpg
L track on front and rear of each panel & on side of each panel.
The design of that roof rack is flawed. I'll wager the checker plate will soon scratch/abraid/shred the surface almost everything that's stacked on it as a result of constant vibrations. "What were they thinking?"🤔
I see static load is listed at 250kg, but no listing of dynamic load.
I understand that the two base elements (together?) have a static load of 250, the middle element, which has to be ordered separately, 150. Wonder if that adds up to 400 then. And I also didn't see any reference to the dynamic load.
Where's the jack going?
They suggest to "put it somewhere else". Doesn't really convince me. Since an aux heater and a marten repellent system are to be my first two installations, I wonder if there is somewhere better to put the auxiliary heater. It would be a shame to lose what little storage space there is.
Yeah there’s nothing from BS I’d consider buying based on those pics.
This is the flattest rack I have ever seen!
It's also 3cm in height. Talk about keeping a low profile to the roof. The hurdle with trucks this size is you add a good 152mm plus the height of from the attachment kit. Which usually makes the height 300mm higher. That puts the truck well over 2150mm tall
From early on Ineos has mentioned how the flat roof with rub strips creates new possibilities for carrying things on the roof. It appears to me that the BlackSheep roof rack design takes advantage of the roof design by resting the platform on these strips and not just blindly following earlier gutter support design that lift the roof rack well above the top surface. I know from earlier responses that some have questioned whether such an approach may be flawed with concerns that it would constantly rub and cause issues so I guess it will be interesting to see how such a new approach to roof rack support pans out in the field.
Agree. With the BlackSheep design attached to, and supported by the grab handles & also supported by the roof strips, the only rubbing would be substantial flex in the roof or in the rack itself.
Subject to more information (esp. third party), I think this roof rack system has, on balance, some really good features:
  1. flexible solution (1, 2 or full 3/4 roof coverage) allowing for tailoring based on type/length of journey
  2. use of airline rails (matches Grenadier options)
  3. super low profile (looks great, helps with wind resistence etc.)
  4. uses the rubber roof strips and so increased static & dynamic capacities
However, attachment of items less flexible than say, a slated rack because of the "full base" approach, meaning more difficult for small items
