Bison Gear Ineos
As much as I like the Bison version, inclined to opt for the one from APB Trading. Main reason being, living in the UK I will pay Polish VAT (only reclaimable with a world of pain and paperwork), Postage, UK import duty, and UK VAT. The UK VAT is not 20% on the basic price of the article but also 20% on, postage, import tax, etc.
Having bought a roof rack, they didn't charge me Polish vat, I just paid UK vat and an admin charge to FedEx. It actually worked out a small amount cheaper than buying it in France.
APB parcel shelf fitted in around 40 minutes. Very happy with the quality, posting, etc. The shelf is steel and is just over 1mm thick. (Not measured, so may have to correct that detail). Fitting was straight forward however, some of the screws seem a bit too long for the domed nuts that come as part of the kit. An extra washer for each fitting may be required. Also, I may look to fit some form of gasket between the shelf and brackets in order to silence any form of drumming noise. Once the shelf is screwed tight, which should be done only when fully fitted, the shelf is under tension and so I was a bit surprised at the noise. This is something I think I can rectify. First impressions overall are very positive.
Only negative is that I can no longer use my wire guard as supplied with the SW. The top fittings have been used by the shelf. It might be possible to jerry rig something but not checked as yet.
For reference I have also fitted the brackets which allow the rear seats to be inclined further. The shelf is set back far enough that I don't envisage any clash of heads with very tall passengers.
PS. Apologies if not directly for the Bison Gear thread however, it is a comparison of what else is out there.
Looks pretty good Cheshire.
Sounds like the squeaks can be ironed out. I would think something like a 3M tape would be good for that. Just enough to hold the offending pieces apart and will aid with rigidity and strength. 👍
Hi Shaky
Sounds are all gone. Absolutely solid now. Added a spring washer to each fitting. Overall, very happy.
Is that a camera mirror? If so, I’m trying to stay moderately low tech, so might not be an option. If it is a light bending mirror, then I’m totally in!
It's a very easy install or your local car toys or other mobile electronics shop should be able to do it. It's a vast improvement over visibility through the stock mirror for me.
My roof cargo shelf has a rattle. Tightened bolts once before and the rattle has returned. Any permanent fixes for this?
Hello,
Certainly, it is feasible. Kindly remove the four plastic covers, two on each side. Beneath these covers, you will discover M8 threaded holes where the shelf is affixed.
Should you wish to maintain the interior's cleanliness, you have the option to repurpose the covers; however, you will be required to perforate holes for the bolts.
Alternatively, leaving it uncovered is another viable choice, eliminating the necessity for any hole-drilling.
View attachment 7840101View attachment 7840102
I have the cargo barrier installed, can I add the Bison Under-the-roof Shelf also or do I need to remove the cargo barrier?
Similar question:
Can the Bison Gear cargo baskets be installed when the original Ineos cargo barrier is in place?
I've been trying to order a roof rack and other accessories for delivery to UAE but when I get to check out I receive a message that no couriers are available. How do I arrange delivery?
FOr what it's worth, I have been trying to place an order to Germany today and I also get "Unfortunately, there are no carriers available for your delivery address."
I have successfully placed an order with the same address in the past
I did get a reply from Bison, they asked me to contact them via email and place an order that way. This will resolve the issue apparently.
