We're Bison Gear, and our mission is to provide you with the absolute best gear for your next thrilling journey. 🏞
Currently, our focus is on the remarkable INEOS Grenadier, recognized as the ultimate platform for overlanders.
First top-notch products are already out in the market, specially designed to enhance your INEOS experience.
But that's just the beginning! 🚀 Soon, we'll be rolling out an entire range of premium gear, meticulously crafted for your INEOS Grenadier.
Stay ahead of the adventure game with Bison Gear – where quality meets exploration! 🏕🔧
Defender77
2:11 PM
Dixie
I had such a good experience with Bison Gear, I just ordered the table for the rear door. Here in the deep south, it appears I can get gear from Poland via Fed Ex quicker than I can from the US west coast.
[This rear shelf is in my FJZ80. Who knew? ]
parb
11:11 AM
Silicon Valley, CA, USA
i got one of these mounts for my hi-lift: https://www.rhinorack.com/en-us/pro...lifting-jack-holder-bracket-side-mount-_43101
I don't have the T-slot parallel to the side of the vehicle, but it looks like it could mount on the cross bar. The holes for the screws on the bracket are about 1mm to narrow but i think i can open up those holes slightly to make it fit.
I assume i have to use a sliding t-nut to mount the bracket to the roof rack? I can't use one of those hammerhead nuts (i assume its not big enough to spread the weight over the channel properly)?
or am i doing something i shouldn't be doing? eg. there is no way to fasten this bracket to the roof properly for the weights and the forces of a hi-lift on this mount?
landmannnn
7:11 PM
The
The website uses a metal plate that slides into the channel, that would seem a lot stronger than T bolts.
Personally I would do the same.
You would have to partially dismantle the rack to get the plates in the channel though.
Logsplitter
7:11 PM
I have the top mount rhino rack , high lift jack mount on the pioneer platform and all hardware including fixings for the T slot came with it. However I’ve got an awning attachment to my pioneer platform where the fixings broke so I got flat metal bar cut to the right width and drilled holes in for the bolts (there is enough depth in the track) only downside is you need a pair of grips to grip the exposed bolt whilst doing the nut up tightly. Coach bolts although not ideal slide in those tracks nicely and have got me out of trouble as spares when other fixings have failed.
bemax
8:11 PM
The Bison Gear baskets are installed. I think they were one of the best investments so far. The space has been useless before and the Chinese bag I bought on Aliexpress for the left side (mounted with to long strings for the strap down eylets and two stripes of adhesive tape…) tended to hang uninspired in its corner (because the adhesive tape didn’t hold it in place)
Now the bag is within the basket, everything is clean and tidy and I have (feeled) more space than before.IMG_1998.jpegIMG_1997.jpegIMG_2001.jpeg
