Bicycle Carrier on spare wheel
CrazyOldMan
1:36 AM
Wisconsin, USA
Yesterday I bought this rack and it's not compatible with the Grenadier 😞
Fabbri, in Italy, makes one called the Gringo Bicci. You can get conversion kits so it can carry 4 pairs of skis, 2 snowboards (or 1 snowboard and 2 pairs of skis), or 2 bikes. For the stock Grenadier wheels, you will need the 300mm extension cables, as well. It’s quite light and mounts in about 1 minute, once you do the initial setup, which is very easy. I don’t use it for my mountain bike (I use a Thule hitch mounted rack with an extender bar) - just skis, but looks like an interesting option. One thing to note - I believe the Fabbri touches the frame - my bikes are carbon frame, so I prefer no-touch options. The site says it’s carbon frame compatible, so I think the part that touches has protection for the frame. If you want a spare-mounted rack, however, this might be your best bet.
I’ve also attached a picture of mine, which is just configured for skis.
Gtzdckhs
8:36 AM
HH
I also tried to install the Yakima and did not manage to do so. Yesterday I installed a French model, which seems to work fine: https://www.mottez.com/de/produits/porte-velo-4x4-sur-roue-de-secours/
Can upload pictures later.
Things to consider:
- not as lean as the Yakima (no folding of the upper part)
- assembly takes a while
- creates issues with the parking sensor (there might be a fix for that)
