ugh...come on...guess they'll need to wrap it for me thenI asked here in CO and they said there isnt much to do about it, other than maybe wrapping it, as someone mentioned above. I havent had them do that, but im getting the same bell
Yeah, disappointing...but i do really appreciate John and Red Nolands approach to serviceugh...come on...guess they'll need to wrap it for me then
Sunday on a simple dirt road I also started to hear a metallic bell noise.
I looked for stones around the underbody and I modified the steering damper as you can see, but the noise persists. I tried to ride without it too.
In these two evenings I checked everything that could be checked and now I have serious doubts that it is the torque converter or worse the gearbox.
In the next few days I try to go to BMW and the dealer
yesterday I went back on dirt roads and made a video.
I am very doubtful that what I hear is the noise of the spring, but to remove the doubt I have to disassemble it.
do you have any idea what else could be causing that noise?
the noise is ALWAYS heard:
- on bumpy roads at medium speed. (at low speed it doesn't)
the noise is SOMETIMES heard:
- on bumps / potholes on asphalt roads
- while stopping or starting (which made me think of the torque converter or the gearbox. yesterday however on a dirt road on a slight descent I put the transmission in neutral and drove a few meters with only the brakes and the noise was still there, so I discard the idea of the torque converter or the gearbox)
View: https://youtube.com/shorts/IuSbJR_ppxo?feature=shared
what is it? a stone?
Howd you get it out?exactly, after weeks of checking the heat shields, the springs, the steering damper and everything else I finally found that f****** stone inside the front left disc that couldn't get out
