Petrol/Gas B58 petrol fuel economy
What is your typical usage - terrain , loading etc?
US owner here. Thanks for posting the sheet. I have been curious about the Rest of World fuel economy numbers from owners with more clicks on the odometer.
To add another data point, the best I've seen for my petrol is 18.6 mpg (12.65 l/100 km) on a 320 mile (500 km) trip on tarmac under ideal conditions. Typical result is closer to 16.5 mpg (14.25 l/100 km).
Is that for the actual calculation or what the car computer tells you?
I'm curious about the divergence of computer vs reality folks see here.
In my first 5 tank refills I found the computer to be about 1-2 liters off in what it claims as average fuel consumption. Computer hovers around ~15.5L/100km (~15mpg) for mostly sub 90km/h, mostly even surface dirt or pavement mountain roads and some city. Reality at the pump is more like 17-18L/100km (~13.5mpg).
Roof rack, KO2s, ~250kg load
Others have noticed this. I remain unconvinced that computers are smarter than smart humans 😁
Interesting to see the @Andras table, so let's post mine too, based on ODO meter readings and real liters filled in my tank
The mean value is 15.29 l/100 km petrol.
No roof rack, mixed driving, but quite a lot of motorway, not very often 4X4 driving, usually not very loaded. no towing at all!
I have also a graph:
Some of the peaks in my first 13000 km were motorways, including German motorways.
But in winter there is clearly a higher fuel consumption, see the steadily rising consumption after my 15000 km (that was end of October).
For those who doubt about it, I have two arguments:
  1. In winter, the car uses more energy: lights, heating, cold motor (worse combustion)
  2. I experienced this with all my previous cars, most being diesels, some were petrol.
I have another graph, derived from the previous one, to prove this, I will not enter in technical details about the mathematics (not really difficult), but the graph is called CUSUM. Don't look at the numbers (they have no meaning), look at the pattern:
  • More or less downward slope in summer, more or less upward slope in winter!
  • An upward slope means higher consumption
  • The strange peaks in May and September are my travels to Hungary: a lot of German motorways and more load in the car.
  • I did not travel in Winter, otherwise I also would have seen strange peaks
Final comment: my ODO meter shows 132 km/h while I am driving 127 km/h according to my GPS. The GPS speed is the more correct speed.
The difference is 4%.
This means that when my ODO meter tells me that I have driven 100 km, in reality I have been driving only 96 km!
Therefore my real consumption is also higher than my table above.
In fact I consumed an average of 15.89 l/100 km petrol.
( again: usually not very heavily loaded, a lot of mixed driving, almost no 4x4, no towing)
Thank you Jean for your precise data and graphs.
Its nice to see you managed to pump 90,94 liters also.😂 When is your next trip to Hungary…?
Btw still struggling with water leak at the drivers side safari window. 😳😡
@Jean Mercier the speedometer does read higher than actual , but is it related/linked to the odometer?
I have no idea. These computers just confuse me.
Is your car a diesel?
If this is a petrol this is very low!
Petrol. Actually, the Grenadier taught me to be a truly prudent and law-abiding driver after decades of very heavy foot driving. Previously my goal was the highest possible average speed, now the lowest possible average consumption... Another form of driving fun...
My son comes over for a week in February, therefore my next trip to Hungary will be or April or June. Nothing planned.
For your Safari window, try to put a layer of Sikalastomer on the rubber joint: this should solve the problem temporarily, but probably you tried that.
I guess so: the car measures the number revolutions of the wheel, and the car computer computes - based on diameter of the wheels) the distance (odometer) and computes also the speed with data of the clock.
@Jean Mercier - In the US, the mixture of ethanol on the gas is increased in winter to help lower emissions. The obvious downside to that is an increase in fuel consumption. Is that also done in your country? Belgium I believe?
Well, wel ... I learn every day: you are right, completely right, never thought about this!
The glass window itself was changed
The water “downpipe” was sealed with sikaflex on both sides of the roof metal sheet
The rubber seal of the window has been changed also by ineos
Now waiting for a complete new window+hinges+new style rubber seal for both windows…..
Till than headlining wet in rain…..😳🥲
