There’s a service campaign for EGR rod. Had mine done. Doesn’t make any difference. I think it’s a precautionary. Not sure it’s a check or replacement.What sort of EGR "fix"?
My engine light is on and I'm having the EGR rod done under the assumption that will fix it, and then the cruise control will start to work again & adblue use reduce to normal Grenadier levels?? Fingers crossedThere’s a service campaign for EGR rod. Had mine done. Doesn’t make any difference. I think it’s a precautionary. Not sure it’s a check or replacement.
My engine came on last week. Took it to the dealers and they told me from factory the O2 sensors plugs had been mixed up because they look identical. All fixed now. Fun and games.My engine light is on and I'm having the EGR rod done under the assumption that will fix it, and then the cruise control will start to work again & adblue use reduce to normal Grenadier levels?? Fingers crossed
Heh heh… I stretched my fuel economy a little far on the highway today at 14.4L/100 all highway. Averaging 99KMH
The “remaining range” box dropped off at 55Km to “- -“ yet I still had 20Km to go to the nearest fuel.
Alas I pressed on.
I turned off all electrical consumables, and set my fridge to idle in attempt at taking the load off the alternator. Not sure if it made any difference.
The fuel indicator still showed 3 or 4 bars on the red vertical bit… coasted into the BP Station.
Pumped in 90.95L of diesel. To the top of the filler neck.
Now I know I have 613KM of range at highway speed on a full tank. I won’t be playing this game again any time soon… HahaView attachment 7858879
Had call from dealer earlier, going in week on Monday, will mention this if it's not sorted, thanksMy engine came on last week. Took it to the dealers and they told me from factory the O2 sensors plugs had been mixed up because they look identical. All fixed now. Fun and games.
Today they sent me a quality survey. I told the truth.
I read it, and am not envious, because:Just hope that @Jean Mercier doesn't read this thread, boy is he going to be envious, you must now be the closest tank emptier.
Haha.jean??
Similar adblue consumption as my Grenadier - before I rejected it back to Ineos.My AdBlue consumption for the first 6k Km was about 6L. So about 1.6L per thousand miles. No towing or "off road" ...mainly a return highway run down the east coast of Aus. Brisbane to Hobart Tasmania. av speed about 90-95 kmh
I hired a Defender diesel at Sydney airport a few years ago.Similar adblue consumption as my Grenadier - before I rejected it back to Ineos.
Now I have a new Defender - which like the Grenadier has a 3 litre straight 6 diesel. But, what is really different, is that I have now done 7,000 miles, and the Defender does not even want the adblue to be topped up.
With 6000 miles on the clock, I frequently get 28 mpg on minor country roads on longer journeys.4,000 miles on the clock an I am getting a consistent 25mpg (11.3l/100km) on my daily 45 mile commute round trip which includes a mix of fast trunk roads and stop-start traffic to get in and out of town.
On a weekend if I head into the countryside for a longer jaunt I can easily get 26.5mpg (10.6l/100km) if I'm sensible with the gas pedal and still don't struggle to keep up with the rest of traffic
The best fuel economy I've recorded to date is an average 27.1mpg (10.4l/100km) on a 70 mile trip each way which ironically involved a fully loaded vehicle and towing a large camping trailer. I can only put this down to driving at 50mph for most of the journey: I've noticed in general that the fuel efficiency drops off quickly above this speed, no doubt due to the barn door aerodynamics!
12l/100km is circa 19mpg.I'm getting just over 11litres per 100km. It's a bit worse at sustained higher speeds, about 12.
There's no way the Defender does 38mpg. Even JLR don't claim that.
Your first statement is incorrect12l/100km is circa 19mpg.
By 'driving like a girl' on a motorway, I could get 26mpg from the Grenadire (before I rejected it) - and 38mpg from the 90.
Ha! Similar 17L p 100km on sand only. Less weighty children and reasonably packed rear. Although only tested on around 280km of sand but still close enough. Y62 comparison 26L+++.Diesel - 600km of 100% sand driving over a week, 3 blokes and a full rear cargo area, various terrain from 80km/hr on hard packed and soft and rutted to inland tracks and gnarly soft tracks - 17.85L/100km for the week. This excluded the highway run up and back.
Landcruiser was more often then not in the mid 20’s on these trips.
Snap! I got a matching score driving around Aberdeenshire country roads over the weekend. The trick is to just avoid town/city driving which makes sense in a 3-ton truckWith 6000 miles on the clock, I frequently get 28 mpg on minor country roads on longer journeys.
