AUSTRALIA: Third party suppliers for the Grenadier
TheDocAUS
4:03 AM
Eromanga
Another option for a pre-built battery box is the ATG Bonza which are often 10% off and include free shipping:
I've got one of these I'm currently using to power a fridge while I'm waiting on parts to replace the secondary AGM with a lithium battery.
The ATG Bonza is using quality cells and BMS and I have personally tested it to deliver just over 100Ah of usage capacity. It doesn't include a DCDC, but does have a MPPT solar controller built-in and I can also recommend the ATG portable 225w solar panel which is currently outputting 215w into the Bonza as I'm camping.
Thanks I will look at it and add it shortly. I have hit the word limit in the posts, making additions hard.
What DC to DC charger are you using with the ATG?
4:03 AM
I took the KickAss BB over to my nephew's tonight, before I decided to keep it!
I test charged the battery on solar and then the alternator, plus I tested all the USB and cig sockets.
Wow it is really nice.
It really is a well built unit.
Mind you the silicone adhesive pads almost weld the battery to the base. As I found out when I swapped the AGM for lithium.
TheDocAUS
4:03 AM
Eromanga
That will be my nephew's problem ! :)
weeman
4:03 AM
I'm using a Renogy 20A DCDC which I had lying around, connected using andersons to the spare invertor stud and fuse. Longer term I've got a Victron XS 50A but that will be for the fixed lithium install.
