AUSTRALIA: Third party suppliers for the Grenadier
Please give me the URL for the seat cover in the picture above.
It is only on FB when I posted that. I have not seen the link at the XHQ Shop so far.
These are the other AU options. A few owners have bought SupaFit seat covers.
SEATS COVERS
  1. RubberTree. There has been one report of fitment issues with the Rubber Tree seat covers here;
  2. Woolly Fleece in Townsville have made custom seat covers for the Grenadier, photos here;
  3. SupaFit seats cover are available now. My mini review of the Supafit seat covers here;
  4. Black Duck seat covers for the INEOS Grenadier are now on their website (thanks @pedrogb);
  5. Nakatanenga Seat Covers here.
SEATS COVERS
wow!
Thanks so much !!!!!
NEW MOUNTING PLATE COMING - 120S AND 250SE
There is a new mounting plate under development for the CTEK 120S and 250SE in Australia. I saw the first prototype today, it still needs to be test fitted. It is designed to work with 2 and 5 seaters models.
Stay tuned.
Prototype has been fitted to a 5 seater model, minor adjustments being made (the fit was a little tight). New prototype being cut tomorrow.
VOLUNTEER NEEDED - CTEK120S and 250SE MOUNTING BRACKET
Anyone in Australia interested in testing a new mounting bracket for the CTEK 120S and CTEK 250SE? The bracket has already been test fitted to one car, but a second vehicle is needed for further testing.
The mounting bracket should work on a 2 or 5 seater Grenadier model. The first test fitting was on a 5 seater Grenadier.
The mounting bracket will be provided free of charge and you can keep it after testing. You will need to mount your own CTEK250SE charger to the bracket. You are required to give feedback to the designer.
If interested, please post below. This is a photo of the pre-production bracket (Prototype 2).
I would volunteer but I already have a bracket fitted.
20241113_151320-1-jpg.7877311
20241113_151330-1-jpg.7877313
This was Prototype 1:
20241104_081556-jpg.7876349
I've got the aux battery but am sticking with the portable battery box for ancillaries , so leaving the factory smartpass as is.
Haven't bought any molle panels yet. But keeping an eye on things , and if the need arises...
There is a new supplier for the INEOS in Australia called EURO FLO: https://www.euroflo.com.au/expedition-equipment-1
I will be adding their products to the list in the coming week. Two products are out or deing tested with more under development including a roof rack, rear table and charger mounting plate.
I will add the rear shelf and the cargo solution (currently under testing).
Our latest model back from the powder coaters...
This offer is still open. Pictures above.
I have a 2 seater MY23.5 and would be happy to test fit - I'm in Melbourne.
The " Simpson" was design to use as much of the space available.
With this in mind we were restricted with the storage solutions available.
So we worked around 2 Oztrail 20 litre fridge / freezers and either 4 or 5 front runner storage cases...
In the picture you can see we have swapped out one storage case for an oven. ( The strap is just temporary. We are working an a quick release bracket so you can remove and place on the stainless steel work top)
Behind the oven is the 120A lithium battery... ( dont worry there is plenty of ventilation space here so the heat from the oven will have minimum effect on the battery..)
The two small spaces in the centre are for the 2x 30 litre approx. stainless steel water tanks.
The open space bottom right is were our pull out pantry will be. ( still being fine tuned )
This will be a double pull out, with the panty, then a stainless steel work-top. You will be able to just pull out the work-top if so required.
You can see we have relocated the jack in to the left hand side "wing".
And a first aid pack fits perfectly at the front of the "wing"
We are looking at making some small pull out drawers to go under the "wings" to make use of this space ... although a soft pouch might work here also.
Also looking at an umbrella holder...
Ok, how does one mount a Ranger Raptor seat in the Gren drivers side? I might be able to get a brand new one from a mate and I want to swap the Gren seat out... aside from legalities... of course.
