It is indeed strange. Coolant system bleeding seems to help. Bleeding
n times seems to help more.
I have again returned to the info in these pics taken from the B58 tech manual. Now I don't know what I don't know, but I wonder if
timing explains some of the randomness of complaints where the heater and AC apparently work for owner A but not owner B. These tech pages are telling us that from engine cold start there is no coolant flow in the main or heater circuits.for a period of time where time is engine operating temperature. Heating of the engine core takes priority. In the B58TU variant, which I think all B58 Grenadiers have, the cooling system is further split into cylinder head, then engine block, then everything else.
This characteristic could be a part of the problem where we see differing reports. Along with coolant bleeding, AC leaks, etc.
1. Until coolant flows in the heater circuit and everything gets heat soaked, the heater and defog function won't be effective (similar to a conventional cooling system but keep reading *).
2. The AC condenser is a liquid heat exchanger located in an engine coolant circuit. It is not a conventional air heat exchanger mounted in front of the radiator. Depending on the which coolant circuit the AC heat exchanger is supplied from, there will be a period of time after engine cold start where there is little to no effective heat exchange so the 'condenser' action of cooling hot AC gas refrigerant before compression back to a liquid state will be reduced until the AC liquid heat exchanger gets coolant flow and wakes up.
Postulation (or maybe complete BS, you choose):
Grenadier heater and AC system operation might be a little bit rubbish after cold engine start - until the engine heat management module directs coolant to the applicable circuits and the heat exchangers become effective. Accordingly, if Owner B is struggling with their system, when is this most apparent? Is it after engine cold engine start? Keep in mind that cold engine is very different to cold ambient temperature. A cold engine start can be at the end of a hot day.
* This is different to a conventional wax- thermostat-controlled engine cooling system where the heater core gets hot as soon as the thermostat opens (and heat mode is selected). Further, the AC condenser is not relying on engine coolant flow to operate. It just uses frontal airflow from forward motion or the engine fan.
