I like the TRITTBRETT (rock sliders) especially as you can lift the car with them ....
Any true rock slider should allow you to lift the vehicle from them....
I will replace the existing rope with it, if it fits, if not it will be shorter.Where will you put it ?
I just spent a small fortune in just looking that over! So many fantastic products that look top quality. Hopefully we can get some feedback from those lucky enough to get their hands on some.The LeTech offerings for the Gren are shown in the file attached below.
LeTech are also an INEOS sales agent in Welzheim, Germany.
The thickness of the rope is quite heavy, I haven't seen it as yet but if it is like most Red Winches there should be enough room for a reasonable length of 10mm rope, in fact if you look at the Red Winch website the "Explorer" models which are similar to the IG winch hold between 25 and 48M of ropeHmmmmm, so you think the reason there is only 11M or rope on the Grenny factory/fitted winch is that Ineos are being tight ar$es and not because it's a teeny weeny drum specifaly designed to fit in a tight space under the car ?
Does it say in the description how tall the drawer system is with respect to creating a flat surface when the seats are folded down? My German is a bit nonexistent.The LeTech offerings for the Gren are shown in the file attached below.
@Krabby Using Deepl, the relevant page translates as:Does it say in the description how tall the drawer system is with respect to creating a flat surface when the seats are folded down? My German is a bit nonexistent.
Dave - I can't see the Grenadier stuff on LeTechs website - can you point me in the right direction?I have to admit that does look like a class act.
The light bar version looks better and less "over the top" to me.
It would probably make less wind noise too.
The drawer system looks really simple and adaptable, with the L-Track on top it would be easy to make a number of different interchangeable platforms very cheaply.
One for the upright fridge mount.
Plastic tub for wet & dirty stuff
I think the extra height of the rear platform would be more useable/accessible with a tow hitch step added when not towing.
View attachment 7818222View attachment 7818223View attachment 7818224
View attachment 7818226View attachment 7818227View attachment 7818228View attachment 7818229View attachment 7818231
They only have a PDF catalogue yet: https://lennartz-technik.de/fileadm...pekt_LeTech_Zubehoer_fuer_Ineos_Grenadier.pdfDave - I can't see the Grenadier stuff on LeTechs website - can you point me in the right direction?
Thank you!They only have a PDF catalogue yet: https://lennartz-technik.de/fileadm...pekt_LeTech_Zubehoer_fuer_Ineos_Grenadier.pdf
Here we are - from the mouth of thr horse....The thickness of the rope is quite heavy, I haven't seen it as yet but if it is like most Red Winches there should be enough room for a reasonable length of 10mm rope, in fact if you look at the Red Winch website the "Explorer" models which are similar to the IG winch hold between 25 and 48M of rope
It is only in German languageDave - I can't see the Grenadier stuff on LeTechs website - can you point me in the right direction?
@MrMike - you may want to view this thread, if you missed it:Yes, my intention is to replace it with 30m of 10mm dyneema
Not being tight, genuinely very little space for the winch in the modern front end that has to comply with so many pedestrian laws for safety as an OEMHmmmmm, so you think the reason there is only 11M or rope on the Grenny factory/fitted winch is that Ineos are being tight ar$es and not because it's a teeny weeny drum specifaly designed to fit in a tight space under the car ?
Do we have any price indication for the letech components?
They have a shop on their website but I can't see these on their yetDo we have any price indication for the letech components?
A couple of prices are detailed in Posts #52 & #67 in this thread.Do we have any price indication for the letech components?
That's disappointingHere we are - from the mouth of thr horse....
Hi Mike,
Many thanks for your message.
The integrated winch for the Grenadier is fitted with a 11mm x 15m rope. The useable length is slightly less but more than 11m.
Sadly due to the size of the space available for the winch in the Grenadier the space is smaller than we would have liked and this has resulted in a reduced drum size. The rope that is fitted is the maximum that you can fit to this winch in the 11mm diameter.
However while the winch line may appear short it does mean the winch is always working in the power band and while we carried winch extensions we never needed to use them for any of the vehicle integration testing that we carried out.
I hope this helps. Please let me know if I can be of further assistance.
Regards,
Neil Br*****
RED Winches Ltd
