I'll say it. The Ineos built in winch is a poor excuse for a winch, but it's the best they could do to have an integrated winch with crash tests and all that. Good on them for giving it a go, but the final result telegraphs it was an afterthought - late in the game - perhaps a request/requirement by the top shelf that the vehicle "had" to have one and this was the best they could do given the existing parameters. Not worth $4,000+.Thanks @Arkaig I did see that, It really doesn't solve the problem of a double line pull over 10m though. While not all will be so, it makes heavy recovery situations like steep inclines over that length difficult.
Double line pull still doable with an extension but you will need to reset after 10m. However the winch load capacity is reduced by about 10% for every wrap on the drum after the first wrap. So a fully loaded grenadier will be at winch capacity after about the 4th wrap, so likelihood is that you would need to reset after about 10m in any case. But if you intend to regularly winch yourself up a mountain then this probably isn’t the winch for you.Thanks @Arkaig I did see that, It really doesn't solve the problem of a double line pull over 10m though. While not all will be so, it makes heavy recovery situations like steep inclines over that length difficult.
10mm Dyneema is about usually 9000kg breaking strain, but safe working load limit is usually about 1/3 of breaking strain so thats about 3000kg a fully loaded Grenadier is likely to exceed that in many cases. It’s max GVM is 3350kg.Yes, my intention is to replace it with 30m of 10mm dyneema
I guarantee that it is fine for 99% of users with proper knowledge and equipment. The remaining 1% probably do need to go aftermarket.I'll say it. The Ineos built in winch is a poor excuse for a winch, but it's the best they could do to have an integrated winch with crash tests and all that. Good on them for giving it a go, but the final result telegraphs it was an afterthought - late in the game - perhaps a request/requirement by the top shelf that the vehicle "had" to have one and this was the best they could do given the existing parameters. Not worth $4,000+.
Extracting a figure out of my.....air, i bet 90%++ of winches on 4WD's are rarely or never used.I'll say it. The Ineos built in winch is a poor excuse for a winch, but it's the best they could do to have an integrated winch with crash tests and all that. Good on them for giving it a go, but the final result telegraphs it was an afterthought - late in the game - perhaps a request/requirement by the top shelf that the vehicle "had" to have one and this was the best they could do given the existing parameters. Not worth $4,000+.
@DaveB 60% of. The time it works every time.Extracting a figure out of my.....air, i bet 90%++ of winches on 4WD's are rarely or never used.
The other 10% are used often.
A turd covered in burned hair.
I don't intend to do it regularly, but it has happened to me twice, and not by choice. What disappoints me the most is that this winch doesn't come up to the same specifications as most aftermarket winches suitable for vehicles of the same weight. There was also no literature available specifying that the maximum usable line would be 10m.Double line pull still doable with an extension but you will need to reset after 10m. However the winch load capacity is reduced by about 10% for every wrap on the drum after the first wrap. So a fully loaded grenadier will be at winch capacity after about the 4th wrap, so likelihood is that you would need to reset after about 10m in any case. But if you intend to regularly winch yourself up a mountain then this probably isn’t the winch for you.
You feeling ok Dave. I feel your maths is unusually imprecise here.....?Extracting a figure out of my.....air, i bet 90%++ of winches on 4WD's are rarely or never used.
Poor excuse would seem a little strong for me. Definitely hamstrung though.I'll say it. The Ineos built in winch is a poor excuse for a winch, but it's the best they could do to have an integrated winch with crash tests and all that.
I'm pretty certain it was on the original fag packet/back of an envelope list of requirements and put there by the top bods themselves. The mistake for me was putting it in the front where it then comes up against packaging constraints and pedestrian safety legislation.Good on them for giving it a go, but the final result telegraphs it was an afterthought - late in the game - perhaps a request/requirement by the top shelf that the vehicle "had" to have...
Just remember according to the "Legalities" in the manual:Pulling logs out of a wood, pulling your mate out of a ditch, pulling anything you will need to do in 8M bits ....
I'd like to ask Ineos how one is supposed to go about these two requirements?Health and Safety and other rules written and dictated by people in an office with little to no practical experience, people who feel the need to get thier nails done, use mens skincare products or beard shampoo and tie thier hair up in a bun ..... people who, with all the best intentions, have ruined a really good idea ...
"WARNING: The Winch installed to your vehicle, both option and/or accessory is a self-recovery Winch only. Do not use the Winch for any other purpose."
"WARNING: It is your responsibility to ensure that before any Winch is operated... the
Winch has been correctly installed by a certified technician."
Does it come with a certificate saying this or should Ineos then provide one?
"WARNING: Ensure the Vertical Towing Interface has been correctly installed by a certified technician, before commencing any winching operations. Contact your INEOS approved partner."
I wonder what my agent will say if asked?
There is/wasCorrect me if I'm wrong but I think there was a MB recall on their portal axled Gs with this system due to cracks.
