AC / heat in rear seat
I have been trying this since I read Leerroy's post a few weeks ago, and the HVAC system has been working reliably, ie without the rear furnace, so there maybe something to it!
In addition, other systems, like the start/stop, have also been much more consistent with what I would expect, and I haven't had the cooling fans screaming at full speed either.
There was once when I didn't follow 'Leerroy's start-up procedure' (yes, that's its name), and the rear vents started blowing hot, but after pulling over and starting up with the procedure, all vents were blowing cold again.
It would be great if others who are having the rear furnace problem give this a go to see how consistent it is and let us know on the forum here.
With more feedback and data, Ineos may actually be able to work out what is happening and eventually develop a fix.
Thanks a million! I will try this today…
Frustrating how we have to perform these work arounds.
I made it 24 hours and 52 miles into ownership and have the full furnace effect in the rear vents and cool ( but not cold) air in front. Letting it sit and will try the previously mentioned start up procedure. Already called the dealer.
I hadn't seen this thread before or I would have responded earlier: I had the same problem and had my Grenadier shipped to the dealer twice, they were not able to solve it. Eventually through trial and error I found a work-around that avoids the issue.
You are now a pilot - you have a pre-departure and pre-shutdown procedure you must follow, here it is:
1) Before starting the Grenadier confirm:
All three HVAC dials are turned completely counter clockwise (i.e. fan off, full cold, front vents selected).
Turn the ignition one click (i.e. before the turning the engine)
Allow all the warning lights to go off (one or two will remain, but essentially you are letting the computer wake up and do its self-checks before turning over the engine).
Now start the engine.
Make sure the a/c compressor is on
Don't use the auto function
Adjust the fan and temp and vent selectors to preference
2) Before shutdown:
Return all three HVAC dials to the full counter clockwise position.
If the problem happens again (it has for me a few times when I forgot step 2), go to step 2 and then shut down the engine. Before going back to step 1, leave the ignition fully off for at least 3 and a half minutes (that is how long it takes the computer to fully shut down).
Doing this has been 100% successful in avoiding and correcting the problem.
So I have tried this for a week and it absolutely 100% works for me. However it is a pain in the ass to remember to do each time and my better half thinks I'm some kind of obsessive nut case so it's a temporary fix at best :)(y)
How long of a drive have you done, to verify it’s not just short term fix? I have many people say the ac stopped working an hour into the drive
I hear you, my wife complains about it non-stop.
I've used this now for about 8000 miles, I've not had a single time where the problem started again when I remembered to shut-down and start up using this (and I avoided using the auto function). I've had the problem return several times when I forgot to shut down with this procedure. But then doing a shutdown, waiting +3.5minutes and restarting with the procedure has solved the issue.
For what it is worth I have never experienced this AC issue (fortunately). I also don't us Auto. I tried it initially but did not like the air flow management. So no Auto since first drive.
So is this a software issue or also a Freon issue? I have also heard some vehicles have low Freon… are there multiple contributors to this poor ac performance or are people simply throwing the kitchen sink at this problem?
Hello, I had this HVAC issue (middling ac in front and blast-furnace in the back) in April and May with my granny delivered in mid January. I couldn't identify what was triggering it our how to stop it. First time it happened I rang the dealer and it was the first time they had heard of it, it had stopped so I did not bring it in. Second time it happened I drove straight to the dealer's service dept and left it running so they would see what it was doing. Thankfully another owner had reported having the problem and they know what to do. The fix was to replace the electronically actuated valve that allows hot engine coolant to flow through the cabin air heat exchangers. No issues since. I think there is a strong likelihood this can be considered part of the electronics and wiring harness problems the vehicle has endured. While at service, I requested they complete the trailer wiring harness fix (that had lingered since delivery). Shockingly, I was informed that the fix fried the infotainment head unit, and regularly does so. So it sat for another month awaiting a new head unit. Everything seems to be working now, but I haven't put many miles on it so cant be 100% confident...
Just to update the situation. I let the truck sit for two hours while receiving and infusion and then restarted it using the preflight checklist method previously mentioned and every thing was back to normal. I think that this is 100% a firmware issue. Ineos really needs to get us a fix for this. I thought that the rear vents might actually melt down from the hot air.
I should add to this thread, to anyone having issues (of any kind), as inconvenient is it may be, let your dealer know about any issues you may observe. The dealer can then let Ineos know, and fixes can be made. I'm a person that is all about fixing it myself instead of dealing with a dealership. But on a vehicle like this (being a new company), if the feedback doesn't get back to Ineos the fixes are never implemented; and as convenient as it would be if there was a way to turn a post (or a search) into direct feedback to Ineos Automotive, that isn't the route.
Super interested in buying one within 6 months, but Florida wise—AC is a must
i had this issue, took it to the dealer. they said i was low on refrigerant. they topped it up and ever since my AC has been great.
AC after being topped up works, heating is another matter, it's in now being worked on. Coolant was low after a blead, which has Ben done about 3 or 4 times, I think the 2 resevoir tanks are leaking as there is residue around the joints
