Still happening, A/C on with heat like a heatgun coming out of rear vents and a mix in the defrots vents....
Its really not tolerable in the summer heat
Yes, I have experienced the same.It seems to occur because with the AC on, some cold air comes out of the windshield defrost vents and cools the windshield below the dew point and causes the condensation. The wipers clear it fine but it requires an intermittent wipe of the windshield to keep it clear. Has anyone else experienced this?
Thanks Phred, mine is set to dash only but I will play with it a bit to see if it helps. I think overall the dampers and control system need some upgrades.Yes, I have experienced the same.
If vent selector is set to feet and dash, some air comes out window defrost. BUT, if vent selector is set to just dash, nothing seems to come out defrost.
Odd for sure…
I hope your dealer can fix it. Mine had no idea and handed the vehicle back and said they would get back to me. It’s been a few weeks. I don’t think there is a permanent fix yet.So the only work around I have regarding this issue of hot rear vents and Luke warm front vents is to close the rear vents and put the AC into auto mode. Then I get cool air in the front and hope I am not traveling with rear passengers. After cycling the engine off for a few minutes cures the problem for awhile. I have an appointment with the dealership here and hopefully they can fix it permanently.
I’ve had the same issues even after the dealer replaced a hose they stated was loose. Just very frustrating how a new car company can deliver a car with such issues especially after all the hype around driving the car a million miles in extreme conditions throughout the world. I’m in Southern California! Great weather state! Maybe that is the problem. I should move to an undesirable location. Excuse me if I sound put off but I’m just a little frustrated these days. I also have to literally slam the rear doors to get the sensor to stop coming on telling me that the doors are open. There are a few other gremlins lurking around.Had our Grenadier 4 months now, air con has now failed 42 times now with exact same problem.
It randomly decides to open heat flap resulting in piping hot air to back vents and a mix of aircon and hot air to the front. No adjustments resolve it. The only resolution in to stop the car , switch off, lock walk away for 20 minutes and come back. Mostly it works, but sometimes it stays the same.
Brisbane dealer says waiting on new aircon hose., so far 2 months---
Seems more like a software issue applying heat flap.
Has anyone had the same issue? If so, has it been rectified.
With ambient temps in Queensland 27 to 35 deg the vehicle is sometimes undrivable.
I took mine to the dealer for the same issue of hot air out the back vents and warm out the front when the AC is on. It happens a few times a week. The dealer replaced what they said was a leaky hose and that the problem was fixed. I told them that wasn’t going to do the trick and sure enough the next day it was blowing hot again. They said they drove it and found no problem. If it happens again during the day I’m driving straight to the dealer and won’t let them turn it off so they can see how jacked up the HVAC system is. It’s beyond frustrating.I’ve had the same issues even after the dealer replaced a hose they stated was loose. Just very frustrating how a new car company can deliver a car with such issues especially after all the hype around driving the car a million miles in extreme conditions throughout the world. I’m in Southern California! Great weather state! Maybe that is the problem. I should move to an undesirable location. Excuse me if I sound put off but I’m just a little frustrated these days. I also have to literally slam the rear doors to get the sensor to stop coming on telling me that the doors are open. There are a few other gremlins lurking around.
I bet there are many more of us that are experiencing this problem considering that the cars are sold in relatively low numbers I’m surprised we are hearing as many issues. Maybe I should have followed my gut and waited till all these bugs were worked out ! Very frustrating!I took mine to the dealer for the same issue of hot air out the back vents and warm out the front when the AC is on. It happens a few times a week. The dealer replaced what they said was a leaky hose and that the problem was fixed. I told them that wasn’t going to do the trick and sure enough the next day it was blowing hot again. They said they drove it and found no problem. If it happens again during the day I’m driving straight to the dealer and won’t let them turn it off so they can see how jacked up the HVAC system is. It’s beyond frustrating.
I hadn't seen this thread before or I would have responded earlier: I had the same problem and had my Grenadier shipped to the dealer twice, they were not able to solve it. Eventually through trial and error I found a work-around that avoids the issue.
You are now a pilot - you have a pre-departure and pre-shutdown procedure you must follow, here it is:
1) Before starting the Grenadier confirm:
All three HVAC dials are turned completely counter clockwise (i.e. fan off, full cold, front vents selected).
Turn the ignition one click (i.e. before the turning the engine)
Allow all the warning lights to go off (one or two will remain, but essentially you are letting the computer wake up and do its self-checks before turning over the engine).
Now start the engine.
Make sure the a/c compressor is on
Don't use the auto function
Adjust the fan and temp and vent selectors to preference
2) Before shutdown:
Return all three HVAC dials to the full counter clockwise position.
If the problem happens again (it has for me a few times when I forgot step 2), go to step 2 and then shut down the engine. Before going back to step 1, leave the ignition fully off for at least 3 and a half minutes (that is how long it takes the computer to fully shut down).
Doing this has been 100% successful in avoiding and correcting the problem.
I'll try this process this week and report back. I have the A/C on 'heat' most of the time as I'm in Scotland, but the system seems incapable of blowing hot air out of the selected vents without also blowing cool air from some place else.I hadn't seen this thread before or I would have responded earlier: I had the same problem and had my Grenadier shipped to the dealer twice, they were not able to solve it. Eventually through trial and error I found a work-around that avoids the issue.
2) Before shutdown:
