Local Area Thread „Serviceaktion“ Türschloss
Schattenparker
6:09 PM
Franken
Für Euch zur Info… Ineos hat ein Erbarmen mit den klemmenden Türschlössern, habe gestern ne Mail bekommen, dass es wohl ne Serviceaktion gibt, die bei der nächsten Inspektion gemacht wird. Muss eh wegen beschlagenem Kompass nochmal in die Werkstatt, vielleicht machen sie das gleich mit…
Hier der Text:
Hi Schattenparker,
We’re aware of reports currently in the media relating to an issue with the Grenadier exterior door button. We appreciate this may have given you cause for concern, so we wanted to get in touch to provide you with more information to allay any concerns you may have and to let you know what it means.
We have identified an issue affecting some Grenadiers worldwide where, in a small number of cases, the exterior door button may remain in the depressed position. This could prevent the door from fully closing. Please note, that the safety warning systems in your Grenadier remain unaffected so you will continue to be notified, should any doors be left open.
We are undertaking a worldwide campaign to replace the door button mechanisms on affected vehicles, and we have notified the regulatory authorities around the world. We will replace the mechanisms free of charge for you during your next routine workshop visit. There is no need for you to do anything now, but please do make the usual check that all doors are closed properly when using the vehicle.
Your safety and driving experience are at the heart of everything we do. We want you to know that as part of our commitment to the quality of our products, we are dedicated to ensuring that your Grenadier meets the highest standards of safety, performance, and reliability.
If you have any questions and would like to talk to us about this, please click below to get in contact.
Warm regards,
Lynn Calder
CEO, INEOS Automotive
Nur scheinbar oder tatsächlich auch anscheinend?
Ich habe die oben genannte Nachricht für mein Fahrzeug erhalten. Mehr kann ich Dir sagen, wenn ich mit meinem Servicepartner gesprochen habe.
Im Konjunktiv habe ich deswegen geschrieben, weil ich vorsichtig bin Behauptungen aufzustellen, dass es alle Fahrzeuge betrifft. Könnte ja z.B. sein dass nur mein Fahrzeug betroffen ist. Oder die Mail fälschlicherweise an mich ging.
Hast Du keine Nachricht per Mail bekommen?
Hast Du die Mail von INEOS bekommen? Ich habe meinen gebraucht gekauft - ich denke nicht, das INEOS meine Mailadresse hat. Kommt dann eine Naschricht vom Händler? In meinem Fall wäre das Matzker.
Die Mail kam von Ineos, siehe auch die Signatur des Mails.
Meines Erachtens müssten die Händler wie Matzker aber auch informiert sein.
Ich habe auch die Email von Lynn Calder bekommen. Und ich habe auch ne Ahnung, warum sie diese Aktion machen. Es ist nicht allein wegen des Klemmens der äußeren Türknöpfe, sondern vorallem weil die Türen (dadurch?) nicht sicher verriegelt sind. Bei mir ist einmal die Beifahrertüre in einer Linkskurve einfach aufgeschwenkt. Warnlampen hatten keine gebrannt. Mein Grenadier hat die VIN ...PF0087xx, hergestellt im Oktober 2023.
[td]
[/td]​
[td]
[/td]​
Moin,
ich habe heute ebenfalls so eine mail erhalten.
Habe morgen bei Krüll in HH einen Termin zur Behebung von Motorkontroll-Leuchte und Rattergeräusch bei 1500 - 2000 rpm und hoffe, dass es gleich miterledigt wird.
Gebe Update zu gegebener Zeit!
Interessant, ich habe keine Mail bekommen.
Meine Türgriffe wurden - bis auf einer - aber fast alle bereits getauscht. Ich glaube es waren drei Werkstattbesuche für drei Türgriffe (u.a.) nun folgt bald der vierte für Türgriff No. 4. Grund war der nicht vorhandene Lieferbestand der Ersatzteile, welcher sich aber jetzt wohl erholt hat.
Ich wüsste sehr gerne, was jetzt genau gemacht wird? Es soll früher einmal einen Versuch gegeben haben, einen Plastikring zu tauschen, jedoch soll dies auf Dauer erfolglos geblieben sein, ebenso Nachfetten.
Bei mir wurde die rechte Seite getauscht. ('24) Hielt aber nicht lange an.
Bei der Durchsicht wurde es noch mal nachgefettet.(1/'25)
Wir werden sehen wie lange es funktioniert oder ob ich auch noch mal deswegen hin muss.
Die E-Mail habe ich auch erhalten.
Das genaue aktuelle Ineos-Wording ist „replace the door button mechanism“. Das genau verwendet auch aktuell der Ineos Customer Service. Nachfetten ist etwas anderes, die Maßnahme muß einen Austausch eines oder mehrerer Teile des oder des gesamten Schließknopf-Mechanismus‘ beinhalten. Leider beschreibt Ineos die Maßnahme mit keinem Wort, was ich verstörend finde. Ich hoffe nicht, daß es um einen Austausch des Plastikringes geht, weil dadurch bereits in der Vergangenheit das Problem nicht ursächlich dauerhaft behoben worden zu sein scheint. Vielleicht lernen wir demnächst mehr?
lt. Aussage vom Händler nicht der Plastikring, Austausch der gesamten Mechanik an der/den betroffenen Türen. Aber wie immer bei Ineos: Der Servicebetrieb stellt den Mangel fest und dann erst Behebung…. u.U. zweiter Besuch nötig. Da kann man nur hoffen, dass der Knopf an dem Tag auch klemmt und die ET’s lagernd sind.
Jetzt wo ich bewusst nachgesehen habe finde ich diese Mail auch, sie kam am Montag. Danke Euch für den Hinweis.
Da ich auch eine rumschlabbernede Türdichtung machen lassen muss (Fahrertür, Dichtung klebt nicht mehr) , warte ich auf einen Termin an dem beides geht.
Das ist ein deutlicher Hinweis, dass die Mail authentisch ist. Wäre ein Fix da beschrieben, wäre das nicht von Ineos.
Soweit käme das noch ... 🥳
Süß, wie sich alle freuen, dass Ineos mal was macht. Bei all den Problemen :D
