WolfBox @ SEMA 2024
Love your products WB!! I have a g900, g900 pro, tire inflator & jump starter. Some of the best accessories available for any vehicle. Once I have my rear cargo storage system set up in my first Grenny, will be checking out your fridge/freezer. 👍🙌
Are you going to make a Grenadier mirror mount so you aren’t forced to use bungies?
I have had zero issues with the rubber straps on my personal grenadier in some pretty rough terrain so I don’t think they are all that bad…l don’t see any negatives with using the straps based on my experiences.
Have to agree with you. I am using the bungies also. Wanted a cleaner install however the alternatives I have seen, just didn’t look clean enough. Besides which, they cost nearly half as much as the Wolfbox itself!!
The 67 Designs is a great mount. It allowed me to move the mirror as far left and up as possible. Blocks the airbag lights. I used the bungie to secure the GPS receiver.
I also used the 67 Designs mount. Although a bit pricey, it is the definitive way to go. Very well made and super clean look. It also makes it harder for someone to steal your mirror.
Thank you for your support! 🍻
A possible idea for future feature or firmware update?
I was at a loooong stoplight yesterday and flipped the mirror to front view to see it since it can be hard to see stoplights in a Grenadier.
Anyway, what if... you were able to trigger a switch back to rearview (or split, or whatever you set 'Default' to) once the vehicle started moving again, or hit 5mph or something?
Just thinking out loud. Love the mirror!
Nice trick, will test!
When the lights are above my head, I look through the safari window (not everybody has them). But it happens that even on the right or left side I am unable to see them, without bending my body.
Happened today. Next time I try you trick!
I guess you're using our G900, right? If it's a G900 Pro, you can just say "show the rear camera" and it will go back to the rear cam. Yes, voice control. And I like your idea, will pass it to the technicians 🍻
Nope. G900 Pro. I talk to myself and yell at other cars, haven't chatted with the mirror. 😁 I'll give it a try! Thanks! 🍻
