WolfBox - As A New Vendor, Offering 20% Off Discount!
3 wire option... ACC, contant power and ground. Turns out wiring into the rear seat fuse panel was a bad idea because I don't have enough cable slack to run power to the mirror.
Easy to piggy back off fuses near ignition. (on RHD at least) Edit note: In this image the yellow pigtail of the wolfbox fuse needs to be coming out of the right side of the connector rather than left - just turn it around so the fuse is working properly, otherwise 12v is not going via the fuse as the left side is 12v hot.
Ball mirror mount on the 2024 trucks. But I could without pulling the mirror off.
If using a Ram ball I am guessing “A” which is the 1/2” if you can find them.
That's interesting! Bare wire straight to fuse sockets?
I'll have a look at mine and measure up later today. Although it would be good to know if any of the earlier vehicles have a different diameter, do we have an @Jean Mercier or @emax with a vernier handy ;)
I made a measurement without dismounting and my Vernier (that I inherited from my father) showed 16 mm in the picture below, therefore the ball has a slightly larger diameter, perhaps 17mm:
Looks sharp.
Any issues with a dirty rear window affecting view?
Also, do you have a HUD? A see a digital font looking 27 in the one frame.
In that spot, the camera gets the benefit of being behind the windscreen wiper so it’s nice and simple to clear the view from time to time. (When I tried it outside it was pretty annoying)
The HUD is pretty good! It’s this one. GPS based and easily calibrated so the speed matches the display once steady (though it lags a couple of seconds, which is why they don’t match in the photo).
I couldn't tell if that cam would be inside the sweep of the wiper arm - that looks like the perfect place to mount - I will probably follow suit.
As for the HUD, they don't sell that one Stateside, but I'm sure something here will work. I was worried that the verticalness of the windscreen might hinder the functionality of the HUD. Does not seem to be the case!
I initially tried mounting it to the small flat shelf on the dash, but the design of this one and my height doesn’t suit that position. Instead, tucking it behind the steering wheel itself worked much better.
Good work on getting the code from Wolfbox Stu. I purchased too early and missed the code! It works well although the cables do slightly interfere with the airbag warning sign.
I bought the extension cable as well so I can relocate the rear cam to the back of my boat when towing.
Something I’m looking at is trying to mount it just above the centre display so it will free up the standard mirror and have the best of both.
Link
Twist anti-clockwise according to @Cheshire cat, but it may need some encouragement.
Now that it’s been a while, I can’t remember for sure if it is CW or CCW to remove. I know it is only needs to be twisted about 90 degrees
might that have a significant effect on your vision? I did think of doing similar but dismissed the idea following a trial fit. Didn’t sort of look right.
Wolfbox G890 mounted to inside of 70% rear door...
I'm thinking of mounting the camera to the steel plate for more articulation later on.
Are you using the 3rd camera for the “interior” or elsewhere?
I decided not to install it for the time being since I'm already using a Nexar One.
From the wiring diagram I saw on their website, it looked like the interior cam was hard wired as opposed to being plugged in. Is that correct? My hope with the 890 was to get a waterproof cam and put in the grill but that doesn’t seem feasible.
Your idea has me holding off for conformation. I love your idea. @Krabby I have to come to Philly for work end of January, in reality not downtown Philly but Malvern. You close at all? I arrive on Monday, you up for a drink?
Enclosed is the correspondence with my questions to Wolfbox
Hello,
do you have a dashcam interior mirror in the program to which I can connect 2 reversing cameras for car AND caravan?
Hey Christian
Thank you for reaching us.
We don't have the dash cam as you mentioned. There only have one port for the rear cable.
But I was wondering if you can install the original rear cable and rear camera behind your car, and another rear camera and extended rear cable behind your caravan, and you can switch the rear cable port to see the exact rearview you need. And you may also need to lengthen the length of the red cable (of the rear cable), which is used to connect your car's reversing light, then it will show reversing line when reversing.
jiShRViot8L5kzJ8amuD_6tyzK3KuA3MfxMI6aPBLn8bvI8Ib_wZXYvqJvlkv3Bd
Hello,
Hey Christian
I’ve been wondering about doing this when I’ve got my trailer hooked up. Switching between two cables (manually or with a relay).
