WolfBox - As A New Vendor, Offering 20% Off Discount!
Does the Wolfbox function as a traditional mirror, or only has a camera display?
This is important as the clamp on design allows you to remove it if it fails. I would like to have a permanent adaptor if the Wolfbox also functions as a traditional reflecting mirror.
I do not believe it is reflective by itself and if a traditional mirror was needed, you would need to remove the unit (which is easy because it's just strapped to the proper mirror).
I have one, and they are reflective. If the screen goes to screensaver than it works just as a normal mirror. Works mint 👍
You can also push the button underneath and it’s goes in screensaver mode.
But the dash cams stay active and are recording front and rear.
Fantastic - thank you!
I think a RAM mount ball mount would work. Or other similar product. Not sure how to remove the Grenadier's mirror but the ball size looks to be smaller than 1 inch.
A heard that RAM, located in Seattle, was digitally scanning the Grenadier this week. I can't wait to see what products they come up with.
I'm pretty much in the same boat as you @Loc Nar, I'm dealing with their tech people right now to work out the best version for the Grenadier. If someone better informed than me knows the most appropriate unit then I'll change the original post to suit.
As an aside, if anyone knows the diameter of the ball for the rear view mirror then let me know as I'm trying to get them to make a Grenadier specific mount. They're somewhere on the east coast so I dangled the idea that a member may be able to drop by and they can take some measurements.
I'll have a look at mine and measure up later today. Although it would be good to know if any of the earlier vehicles have a different diameter, do we have an @Jean Mercier or @emax with a vernier handy ;)
The mirror (Y23 models) is connected directly to the windscreen. This is different for the Y24 models, they use another system.
Whew! Finally got the hardwire wiring figured out. If you have a Trialmaster, these are the fuse sockets and ground I used in the under rear seat fuse panel...
Now to mount camera and mirror and hide all the wires. Many thanks to Cheshire Cat for the help.
Whew! Finally got the hardwire wiring figured out. If you have a Trialmaster, these are the fuse sockets and ground I used in the under rear seat fuse panel...View attachment 7838654
So you went with only the 2 wire option and not the 4 wire?
This is my experience also. The mirror would work in a conventional manner however, currently, because of the wire connections on top of the mirror I can’t tilt the mirror far enough to use as a conventional mirror. I think if I change the mount I will have more success.
Just for balance. My daughter doesn’t like the digital mirror. Unfortunately her dislike is not articulated very well unless anyone can translate a shrug of the shoulders and silence?
The digital image is different to a real mirror however, the flexibility and fantastic rear vision is in my opinion, well worth it.
Hi Cheshire cat, I have a 2020 New Defender with the digital mirror and love it. Will be getting a WolfBox once my Grenadier shows up in April 2024. Once you have experienced a digital mirror you always want one. I found it takes a little while to get used to it until your brain syncs to it as the perspective in the digital mode is a bit different than when just a mirror. DaBull
100% agree with you DaBull. I took some inspiration from the new Defender and mounted my camera on the roof. Allows me to see over my trailer. I do have to remember to wipe the lens clean more often but so far, no other issues. For the record. I did not drill holes in any part of the vehicle or the plastic trim.
EB told me the same today. Excited to see what they come up with. Hopefully it's not just their laptop mount. I'd love some track on the dash similar to what @globalgregors has.
3 wire option... ACC, contant power and ground. Turns out wiring into the rear seat fuse panel was a bad idea because I don't have enough cable slack to run power to the mirror.
For the record. I needed the additional wiring extension to comfortably connect my rear camera. For main power I connected into the cigarette lighter fuse in the small fuse box near to the steering wheel.
Does the Wolfbox do well adjusting for the light coming at you from behind? IE handles the view with no one behind you and can adjust when there’s a lifted F250 on your ass?
Please provide a picture of the locations of the fuse connects, if you don't mind, Phil. I'm at my wit's end trying to find the proper fuse connections. I ended up using the cigarette lighter power cord for the time being just to get the camera up and running. :) It's working, cords are hidden, albeit with cigarette lighter plug power.
Apologies. I misunderstood. I used an extension cable as well.
Home on Monday. Will see if I can find this thread and post pics.
Ball mirror mount on the 2024 trucks. But I could without pulling the mirror off.
If using a Ram ball I am guessing “A” which is the 1/2” if you can find them.
