Where is the front auxiliary power point?
Definitely the pics look nothing like my layout - RH drive diesel. I'm guessing the pics are from a petrol engine... Still, I should be able to see the take-off point - but I can't.
Mmh - it's enough to start a conspiracy theory on... Mind you, this is the RH side and I've read the 25A connection is on that side. And I can't see anything suitable on the LH side.
You said back in post #5 you have the basic station wagon. Just to confirm, you did add the optional HIGH LOAD AUXILIARY SWITCH PANEL & ELECTRICAL PREPARATION in your order? Sorry if I missed that somewhere. You did mention a winch switch in #16.
'Four additional, high ampage, pre-wired auxiliary switches with fuses and wiring running to various points in the vehicle. This option allows for quick and easy installation of aftermarket accessories such as winches and light bars and is activated using dedicated switches in the overhead console. This option includes four external electrical sockets in the tie-down rail recesses.'
Ah - good question. The pic is of my overhead panel. I did read somewhere that the 'pwr' switch simply keeps the USB port live for charging even when the ignition switch is off. But that should still leave me with one external connector somewhere...
So you only have the 10A outlet on the right hand side as you are looking into the engine bay
Here is where mine is on petrol version RHD circled in green
I'll have another look tomorrow to confirm, but no. See pic above. If we assume that side is for the 25A conne3ction, I have to really search hard on the other side...
According to your picture above you don’t have the high load auxiliary wiring but you should still have the 10a supply under the bonnet but not the 25a supply
According to your picture above you don’t have the high load auxiliary wiring but you should still have the 10a supply under the bonnet but not the 25a supply View attachment 7825388
I give up. After spending even more time under the vehicle and leaning over both sides into the engine bay, I have followed the wiring loom and NO TAKE-OFF POINT. It's not there. Now all I can do is complain, and I'm afraid that apart from the good folk here, there will be nothing but deaf ears.
The 10A should be there anyway. Ask your dealer, but sometimes they don't know either
The dealer has already been asked. Here is their reply :-" "
I'll let you all know if anything changes. I'm sure you will be letting me know if anything comes to light.
