What Rocksliders / Side Steps did you choose
I think I'm misunderstanding, but since sliders protect break-over impacts and to some degree low/lateral impacts to the doors and mid-body, wouldn't fenders be vulnerable regardless of the slider design? Brush bars would be necessary for such protection, or maybe a rear kickout if dragging an obstacle across the slider.
I don't ask to be pedantic, but in an effort to refine my armor strategy since I'm highly considering the Agile sliders.
The slider took a upward hit, it was very minor in both speed and the tree itself was just a couple of inches in diameter. He was sliding sideways down a slope at an absolute crawl. Since the slider was attached to the rocker, it transferred the hit to the fender. It crumpled it upwards. I assume the rocker was also damaged but that was hidden behind the slider. It was a Genright slider on a 2020 Jeep JLU.
I went for the slider from Offroad Tec….really like the stile. Made from stainless steel, super beefy build, zero impact on the clearance. I am very happy with this stuff. View attachment 7888366
Those look great and I wasn't aware of those, thanks for sharing. I sent an inquiry to verify they ship to the US as the site suggests they do.
The photos on the site show the forward and aft mounting points to the frame. Is there a center mounting point as well? Would you mind snapping a picture under the slider next time you're out?
Yes - there is a center fix as well. As soon as it stops raining and zero degrees I will snap a photo and post it here. 😉👍
Correct, rocksliders protect the lower body section between the wheels. There is the potential on rocky terrain to damage the rear corners which would require a wrap around rear bumper to protect that section. I don't think brush bars are a good solution, both in terms of strength and aesthetics.
They look very good. Do you use them as a step/ are they working good as steps?
Yes, you can use them as steps as well. Depending on your size it might be a bit of „stretch“ 😂👍.
The real/ original steps are more comfy…..but these cost clearance and I had some rather hard „contact“ with them on stones/rocks.
Therefore I went for real sliders.
For me it works really good.
I struggled to think of what I wanted to spend the $2k accessory credit on and got the OEM sliders (not the steps). They seem ok for what they are but because they are basically flush to the door sills there is slightly less protection and they are useless as steps. I grabbed the black sheep steps which work pretty well and actually look ok. It's a decent compromise for now
Here you go, front, center and back
You also don't know he quality of the slider. back when I had an fj55, it wad common for the rockers to rust, and the "fix" was to weld in a new rocker that was 1/4" tube. I don't recall anyone having any such issues. You could slam and slide it all you want. in a 20 mph t-bone impact something that transfers energy to the frame is probably going to crumple less, but that's outside of the realm of what these are for anyway. Your typical Gwagon slider just attaches at the three points provided for the side steps and all is fine.
My only issue with the agile, is them having quite a wide flat surface (awesome) that seems to have no gusseting (bad). There's no beam depth to resist deformation in the vertical plane. It lacks the requisite edging, creases, hems or flanges, that provide rigidity to flat sheet, and I don't understand why.
I don't like that at all. The entire underside of the Rocker sheet metal is exposed directly in line with where I'm going to place my tires to clear an object, I know I don't have the breakover to accommodate, and I'll deliberately use the slider. It does look like it would be easy enough to attach a piece of edged plate or C channel spanning mounting point to mounting point though, buts another 30-40lbs a side.
Sliders are not just protection, they are a tool in your toolbag and need to function as a slide.
Many thanks. The design of center mount seems a bit counterproductive. It doesn't look like it's going to provide any strength to vertical impacts while making for another point to hang up on rocks. As a counter example, here's Dissent's mid-mount -- still a hang-up point, but looks strong as frigg.
Also a good point. Seems like almost all of the sliders being made for the Gren so far lack that feature.
Sliders were always rather basic. 2x3 tube that was directly under the rocker sheetmetal, and if you wanted a step or some stand off, a DOM tubing extension. CA tuned and White Knuckle appear in the pictures to follow that recipe, and the body mounted Agile units would be awesome if they had some vertical cross section somewhere. I'm not keen the thin body sheetmental on the backside taking the vertical load. Like the Signatures though, I'd think easily remedied with welder.
+1 on White Knuckle. 20º no rear kickout variant.
[edit to attach photos]
Im in the same place. Got the factory sliders installed on credit and they look great but with the height of truck, a step would be great.
How are the BS steps holding up? Any pictures you can post?
Actually I think these are off my list, just 4 steps are over 1k! Wow
Has anyone sold their factory rock sliders? Have my eyes on the Signature Autosports steps once I saw the cost of those black sheep steps and just wondering if there is any demand for the factory sliders.
Several have sold in the classifieds section
If there was some way to remount the factory sliders where they are 1-2 inches out further from the body, they would be prefect for me. Just enough space for the kids to use as a step. May crawl under this weekend and see what I can see, but I’m guessing it’s a no go.
