Just added a Dutch fuel mobile bar for Christmas... Converted Jerry c
an..... So cool!
Just a quick little prototype project that I came up with at 3 am this morning.
Off to the hardware store at 7:15am and 8:30 am I started to build it.
Finished at 11:40 am.
Very rough so far and I will live with it for a few weeks, make any changes then trim the edges, recess the hinges and cover with carpet.
L track will come up onto the sides and I will bolt it down to the L track old mounts.
It holds 4 large plastic storage boxes underneath and gives me a flat floor a bit over 1520 mm x 1200 mm (59" x 47")
I designed it also so the back seats can be both up, both down or either one up or down.
All up it cost me AUD$92.00 USD$57.44 or 55.24 Euro
I got a 25 Litre fridge freezer for christmas so will mount that in the back.
Yesterday, Santa got me the red Owl accessory rail, which I mounted. Early this morning, I drove out to the Driftless to scope out some trout spots for when the season opens in several days. Thought the ground was just wet when I got out on the driveway to put up the WeBoost antenna - black ice. Did a hard cartoon fall on the driveway - style points. Took some ibuprofen and shook it off. Came on an accident that had just occurred on the back roads in the middle of nowhere - SUV slid through a turn, went over the edge and flipped in a ditch. Checked the driver for injuries and talked her through it (after making sure there was no leaking fuel). The fire department came with extraction equipment (yay WeBoost). Grenadier with snow tires handled brilliantly on black ice asphalt, dirt roads and in the snow off-road. VERY thankful for all the advice to prep for my winter obsession with trout fishing. Thank you @Stu_Barnes and @Krabby for putting this together, thank you @anand for your WeBoost wiring advice, and thank you to everyone who weighed in on winter driving/tires.
View attachment 7882479View attachment 7882480View attachment 7882481
I just checked with a laser and the dimensions are 1502mm x 1375mm or 59.13" x 54.13"
Installed my Agile Offroad A-pillar grab handle that my wife got me for Christmas. I took my time and it took an hour. If I were to do it again I wouldn’t take as much time/care cutting the holes in the trim because they just get covered up by the handle. Probably a 20-30 min job if I had to do it again.
I think I’m really going to like this. It’s solid aluminum with a textured powder coat finish so it looks like the factory one, but feels much more solid.
Well done Agile team!
I started mine with the same idea. Then a water tank. Then a fridge slide. Then a drop in shelf for when there is no fridge, for a flat floor. Then a drawer on Teflon sliders. It all starts somewhere, and options are endless so long as you have a solid base.
I kept my floor insert in for sound insulation. Removed the tiedown rails. Inserted spacers so when I bolted floor down it didn't actually compress the floor, more so just rested on it. The random 3 pieces helped elevate my water tank enough to get as close to seats as possible and ensure it and my fridge both fitted. (Also removed the plastic trim at the base of the seats).
I measured numerous times but I feel I still kind of fluked it. My design ended up allowing a 35L poly tank. A fridge slide for my busham 35-52L fridge. And a gap off the door of 30mm. Which allowed a home designed drop down table.
This with my new kaon shelves is amazing.
Dogs too were happy with drop in shelf.
Adequate space in drawer and platform above allows for 2 front runner cub boxes side by side.
Installed both Agile off-road grab handles, drivers and passenger. Quality is great, easy install using just a box cutter and their template. Added the Owl accessory rail with ram ball mounts as well.
First test with the new shelf/storage system went well.
I went to Bunnings hardware yesterday and picked up a load of plywood to roof and wall the bedroom in the grenadiers shed.
16 x 12 mm thick sheets 1200mm wide and various lengths, 1500mm, 1200mm, and 900mm
Around 160 kg total.
Saved $50 in delivery fee and had it home straight away.
I didn't notice before but right hand upright looks shorter than it should be.
I measured it and it is 12mm short, assume I cut it crooked as the cuts were all done freehand.
I guess I have to accept I am an electrician not a cabinet maker.
Thinking I will change all 3 sides to 18mm plywood anyway as I want to be sure it will carry about 350kg easily.
View: https://www.youtube.com/watch?v=9u7Zm_R7IgA
Happy and pissed off today with the grenadier.
Happy that ripping a tree stump (small but stubborn) out of the ground with my drag chain was a simple job with no fuss.
Pissed off because the tow hitch receiver is smaller than the standard Australian Hayman Reece type (that every single other manufacturer and third party seller uses in this country), so my recovery hitch doesn’t fit, not even close. So I had to use the retention pin to secure the soft shackle. I was ok with that because it wasn’t a tough job.
Come on Ineos - it’s not that bloody hard to use standard sized tow points for the various markets you sell to ffs.
So now off to my local 4wd accessories store to spend money on something I shouldn’t really have to.
Grrrrrr.
Anyway, 1st world problem.
Grrrrrr.
I used a Mr Hitches tow tongue as the hole on the supplied tounge was incorrect for my DO35, went in no problem.
1. Fifteen52 Wander SV wheels in 17x8 et40.
2. Mickey Thompson Baja Boss A/T 255/85-17. No rubbing on this tire/wheel setup.
3. OWL spare relocation bracket set on one hole from furthest left, rear row, but could use only 3 of the 4 set screws.
4. GP Factor brush guard. Straightforward installation, fits great, looks good.
5. Fox non-adjustable steering damper. The 21mm side seemed to have a welded nut, so only one wrench was necessary there.
6. Urban Automotive single tube side step. Not pictured. Installation is still as challenging as described in posts from Q1 and Q2 2024; manufacturer has not implemented changes to tighten up tolerances.
7. Wolfbox rearview.
8. Warranty work: passenger footwell dripping, hood closure sensor broke off, TPMS sensors reading as one tire missing, check engine light related to fueling, steering pulled right.
Odometer rolled over 1k today. I like the car a lot off road. I might do some Dynamat in the rear cargo area and maybe a stereo upgrade, but otherwise it's now dialed in perfectly for me.
Fitted King shocks and stabiliser. Reason, I wanted to.
Don't want to start a debate
Though the biggest improvement this week was having drivers seat base firmed up and a lumbar support built into the seat back.
Anyone in the south want to try the mods you are most welcome.
To me its all very noticeable.
What did you torque the king front and rear shocks to?
Grrrrrr.
I have seen conflicting information on if it is a 1 7/8 or 2"
Same. Specifically this one to get the correct rise to level out my hybrid camper.
I did need to shorten the shank and re-drill the pin holes due to the shallow Ineos receiver.
Well I made it to 365 DAYS !!!!
Its been an incredible 365 days with my INEOS Grenadier
So many fun and exciting trips all over Utah, Colorado, Arizona, Idaho, Nevada.
met some many great people along the way, looking forward to 2025
Safe Travels everyone
Day 365 - 29,285 Miles, More Adventures Ahead
