holdmybeer
2:31 AM
Vancouver, BC, Canada
HO HO HO
alex3dworld
5:31 AM
Miami, FL, USA
Looks so good. Had the same in the Raptor for 4 years. Saved me (and others) many times. I had the rear camera also. Was looking at how the Blackvue might fit in the Grenadier. Do you have any details on the install? Fuse used, wire routing etc. Would really appreciate.
Installing the BlackVue Camera in the Grenadier
I installed the system myself, as I’m pretty handy with low-voltage electrical installations. I didn’t use any fuses or tap into random 12-volt lines. The Grenadier comes equipped with two internal, dedicated auxiliary 10-amp cables, perfect for this purpose. You can find information online or watch a few YouTube videos showing their locations.
The BlackVue battery is smartly designed with a switch at the back, allowing you to select between continuous voltage from your car battery or cutting off power when the car is turned off. This ensures it won’t drain your vehicle’s battery. I went with the Smart Battery Plus along with an extension pack, which provides days of parking mode recording and cloud access. Both units fit perfectly under the passenger seat as you can see in the photos, i bought a plastic Project enclousure box from amazon to fit the batteries inside and slide it under the passenger seat. it's hold in place with a good industrial grade velcro.
Here’s the basic installation process:
  1. Power Connection: Run power from the Grenadier’s 10-amp auxiliary cable to the BlackVue battery, and from the battery to the camera.
  2. Cable Routing: To run the cables inside the front passenger column, I used a 3-foot electrical fishing line, which made the process much easier. I then tucked the cable under the roof liner using a soft plastic tool to avoid damage. you may start runing the cable from the camera location side to left the perfect amount of cable to reach the camera DC plug.
  3. Camera Integration: The most challenging part was tucking the cable inside the plastic housing of the front car camera. I couldn’t figure out how to remove the gray plastic cover, so I just carefully tucked the cable inside the plastic box. It’s doable, and the BlackVue cables are practically bulletproof.
The entire installation took me about three hours, as I took my time. I used shrink tubing for connections and wrapped the cables on the floor for a clean and professional finish.
If you’re considering adding a second rear camera, that’s probably another three-hour job—lots of fun, right? 😂
pmatusov
2:31 AM
San Diego, CA, USA
Installed FrontRunner rear ladder.
The price is exceptional compared to factory, quality - good (but consider using your own stainless fasteners rather than supplied).
FWIW, the standard rubber grommets (1" ID, 1 3/8" OD) are absolutely perfect for this, as no grommets were included in the kit.
vtgrenadier
5:31 AM
Vermont, USA
Do you prefer the flat ladder steps? Or do you not have a basis for comparison? I ask because this photo suggests that there's a lot more "purchase" for one's foot...
Jeremy996
5:31 AM
It's been a strange day today. Drove 60 miles to Bloxwich in the West Midlands to bury a mate, aged 59, who died of sepsis, a urinary tract infection, non-Hodgkins Lymphoma and Covid, as I organised his funeral and I am his executor. Blustery drive, so I was glad of the Grenadier.
Des was a butcher for one of the big supermarket chains for most of his life; I'd known him since 1978, about our only shared interest was classic cars, so we'd go to the Classic Car Show at the NEC every year, in the LR110, then the Grenadier, which he very much approved of, (at 6' 4", he was too big to fit in the Morgan or the MX5).
It can be a bit "old school" in Bloxwich, so Des, (and his partner 3+ years ago), had the horse drawn hearse. I followed the hearse on foot from the house to the service and then with some of the congregation to the cemetary, where he was buried with his partner and step-son. There is no one left in his family, as we cremated his brother about 18 months ago.
There is a house and two cars to dispose of, with all of the proceeds to go to charity, 50% to the Midlands Air Ambulance and 50% to The Dogs Trust. There is an ownership dispute with the house and one of the cars, a 1960 Morris Minor Traveller is in small pieces over a lock-up, shed floor, walls and roof space; being executor sometimes is not simple or easy.
The 60 miles back was uneventful. if slow, with a lot of traffic on the M6, M69, M1 and A46. The highlight was being overtaken by an Inky Black Grenadier on the M6. The tailbacks made me grateful for the automatic transmission.
This evening, we fetched my son from Grantham Station, as he is back from Newcastle Upon Tyne for Christmas. Heavy rain and a strong breeze, with localised flooding made the 17 miles each way rather more fraught than usual, so the Grenadier was a more suitable steed than the other cars we have at home. The odometer is now over 30,000 miles and climbing at about 2000 miles a month.
9:31 PM
That there is , but I have found grip tape on the factory ladder tubes has worked very well and is durable - dozens of trips up and down.
vtgrenadier
5:31 AM
Vermont, USA
There is something both somber and elegant about what you put together... that mode of transportation is far and away better than our USA version. Sorry, Cadillac fans. Cheers to you for honoring your longtime buddy.
My mother passed away three weeks into COVID, from COVID (the alternative was much worse, as she was by then fully paralyzed from ALS). I tried to put together her final ride via Land Rover, as she shared my affinity for the brand, but the best I could do was have a custom casket in as feminine (and Land Rover-esqe) a color as I could come up with. A couple of screws and a badge from my first (of dozens) of Land Rovers was as much as I could pull together with all of the distancing requirements and such. Her walker and wheelchairs had LR badgings as well... a 'rover of the land.' To say that she supported my automotive disorder would be an understatement!
Sorry to be morbid. Love you, Mom!
Todd
5:31 AM
Augusta, GA, USA
Relatively new here, a few things done in the few weeks of ownership:
- Lamin-x yellow film on the aux lights
- bike fork mount added to the ladder (freedom coast and amazon pipe mounts)
- dynamat under the rear floor mat (I'd estimate it reduced the booming by about 30-50%; only need 3 of the individual sheets, not the whole kit)
- bison gear boxes in the rear
- spray painted the roof bars black
- modest window tinting (photos are pre-tint)
- generic rope grab handles on headrests for rear seat ingress
- Bosch icon wipers (OEM wouldn't stop chattering)
Walter
5:31 AM
Toronto, ON, Canada
RIVAL Front and Rear Differential Skid Plate spray-painted and installed.
View attachment IMG_6229.jpgView attachment IMG_6356.jpgView attachment IMG_6360.jpg
While installing the front differential skid plate, I noticed that the front driveshaft seal was broken, with oil covering the surrounding area.
I contacted the Toronto dealership, Dilawri INEOS Grenadier, and was informed that this is the first driveshaft failure they’ve ever had.
I haven’t received any follow-up from the dealership since the call, so I plan to contact them again tomorrow to follow up.
shiv.nandak
5:31 AM
Pittsburgh, PA, USA
View attachment 7881731View attachment 7881732View attachment 7881733
View attachment 7881734View attachment 7881735View attachment 7881736
That looks like a much more extreme angle than mine, I guess you have a lift?
Logsplitter
10:31 AM
I wouldn’t want to be driving that. Get it fixed before driving anymore. If it fails completely as mine did whilst driving other damage can occur whilst it’s flailing around. Mine broke the oil cooler pipes for the gearbox and I spilled all the gearbox oil out onto the road. The consequences of this could cause a catastrophic accident if at speed.
