That’s a neat jobhttps://www.theineosforum.com/threads/fixed-air-compressor.12412482/post-1333206516
Hi everyone, I have finally successfully installed my ARB compressor (ARB KOMPRESSOR 12-VOLT, CKMA12). Thanks for the tips @Highwayman. First I ordered a plastic plate 8 mm thick. I used cardboard to press off the bolts and drilled the (8 mm) holes in the plastic as a template. Then I deepened it to 4 mm with the milling machine so that the nuts lay flat with the surface. Next, I inserted threaded claws into the plastic from below to attach the base plate of the compressor. There are rubber rings under the plastic plate. Then first test. Everything fit. So attached the plate with screw glue. The base plate of the compressor too. But I had to remove the auxiliary battery to get proper access to the screws to finally fix the compressor. I connected the electrics first (thanks to Highwayman's recommendation) after removing the FI13 fuse. I shortened the long power cable by about 120 cm. I didn't braid a new short wiring harness for everything. Someone did it but I couldn't find the post. The connections for the air locker (which I didn't need) have enough space and stayed on the wiring harness. Finally, I sawed a hole measuring 21 mm x 36.5 mm into the rear cover of the battery compartment on the passenger side (LHD) for the switch. See photo. The compressor works perfectly, protected with 40 A via the FI13 with the ignition switched on. “Oh what a lucky man, he was…..” View attachment 7828356View attachment 7828358View attachment 7828359View attachment 7828360View attachment 7828361View attachment 7828362View attachment 7828363
