XHQ TOWING PACK IN MORE DETAIL*
Expedition HQ package replaces the 13 pin Euro plug with a 7/12 pin flat pin plug and 2 Anderson plugs (one for the caravan/trailer and one for the solar blanket). This is what the rear now looks like:
The XHQ package is not spliced into the INEOS electrics, but uses its own control box, shown here:
![IMG_8870.jpg IMG_8870.jpg](https://ineosforum-data.community.forum/attachments/7823/7823117-61522554311982d5dcf42febc7a556bb.jpg)
The fuse labelled Anderson, bottom centre, is for the two Anderson plugs for the fridge running off the AUX battery (see more below). The small circuit breaker top right (just below the AUX Battery label) is for the REDARC TowPro and the large 50 amp circuit breaker, to the left, is for the XHQ Control Box.
In a 5 seater Grenadier the control box fits next to the CTEK 120S. The CTEK 250SE then fits on top of the XHQ control unit. There is not enough vertical room in the 2 seater for the CTEK 250SE to be mounted on top, so an alternate place was found, near the aux battery. The metal lid in the 2 seater leaves less room above the XHQ control unit for the CTEK 25OSE than the seats in the 5 seater model.
In my 2 seater the CTEK 250SE was mounted on a Black Sheep charger bracket I already had (the two solar Anderson plugs are attached the CTEK 250SE's solar inputs. The solar input LED is not on as no solar panel was attached when the photo was taken):
In addition, Anderson plugs were installed into the side of the battery box and into the area near the jack. Here is the passenger side of the battery box, just below the lid hinge:
The Anderson plug near the jack will have this plugged into it, which will be mounted next to the drawers:
Out of picture is the Anderson plug that will fit into the jack area Anderson plug.
*FYI: the work I had done included more work than just the standard XHQ Package No 2.
