Gutter maintenance, The corners accumulate stuff , esp if you park outside and have little spiders.
Front rubber trim no problem. Rear trim ; well you will want to hold the rear piece in with one hand whilst prying the corner bit enough to clean. That rear trim piece is held on with a little white plastic clip which pops out of the rubber and gets stuck inro the panel side. It is a PITA to remove and then replace into the rubber, believe me. And there is another one beyond that.
I didn't want to risk breaking this delicate plug either, so I trod carefully.
If you experience salty conditions , you probably don't want salty grunge collecting in these areas, so preventative maintenance is wise.
I used some spider surface spray after cleaning.
View attachment 7841835View attachment 7841836
