Weird wiper error
Baron von Teuchter
1:19 PM
NE Scotland
First things first, they are working absolutely fine. So are the washers.
How do I get rid of this error message?
Eric
1:19 PM
Scotland
Did you by any chance have very cold weather up there last night? We had -5° down here, did they freeze overnight. I have screen wash for -15°. Being heated I wonder if the error occurred as it defrosted for some reason. Just pure speculation probably just an Ineos electrical gremlin
Baron von Teuchter
1:19 PM
NE Scotland
Thanks.
It was cold (-6 at 7am), though the Ineos was in my shed. Wipers weren’t stuck on the screen due to frost or anything like that.
Baron von Teuchter
1:19 PM
NE Scotland
When I got this, I disconnected the -ve battery terminal, pressed the horn/brake pedal and reconnected the battery.
That cleared it.
Thanks, I’ll give this a go! Do I need to roll up a trouser leg and chuck some salt over my shoulder too? 🤣
Eric
1:19 PM
Scotland
Before you go to that trouble, ( of rolling the trouser 👖 leg up) have you checked " warnings" in the infotainment screen and cancelled it there.
The other thing to try, treat it as a service reminder warning. vis a) when running, highlight the warning using the end button on the stalk b) select it again using the end button, then c) select any option on the main screen ie home, offroad, audio or phones. That stops the service reminder but it reappears at the next ignition on.
Baron von Teuchter
1:19 PM
NE Scotland
Great thanks, I’ll give it a go. This is the first error I’ve had in exactly a year of ownership (to the very day!) so I’ve never had to wipe one before 😂
landmannnn
1:19 PM
The reason to hit the horn etc is to fully discharge the circuitry. It's a pretty standard reset for most cars, pretty much does the same thing as CtrlAltDel on a pc.
Trialmaster
1:19 PM
North of Watford!
Had the exact same - frozen wiper blades to screen, which caused the message. This happened while I was fitting the drivers side grab handle yesterday morning (Cost £120).
I reset, by disconnection the main battery for 30 seconds. I then get another message which I cleared with a 10 second disconnect. On 2nd power up - had locker messages flashing - moved vehicle and all fine.
snowball
5:19 AM
Northern BC, Canada.
I've had this error for a couple weeks now. No cold weather when it started (single digits but not freezing). It's been the only one I've gotten that didn't clear on the next cycle.
Glad to get some trouble shooting tips from you guys. Seems this board always has something when you need it.
beg
1:19 PM
Scotland
Ok so I've got the wiper error light on (frozen windscreen after parking overnight in rain then big freeze) whats the consensus is it disconnected pos for 30 sec or can it be rectified via stalk button ?
Eric
1:19 PM
Scotland
Have you tried clearing it in the warnings in the settings menu?
beg
1:19 PM
Scotland
Can't seem to highlight it to clear was trying earlier can you advise how you did it thx
Eric
1:19 PM
Scotland
I haven't had that warning, but I have cleared other warnings that way, but had to clear the service indicator warning via the stalk button but it reappeared after ignition turn on again until serviced by the dealer.
landmannnn
1:19 PM
I tried a whole number of variations with the stalk, holding the warning on the settings screen, tapping it multiple times etc.
It wouldn't work, but I know the battery disconnect does the trick. Probably best to wait 10 minutes after turning off the ignition to allow it to go to sleep from reading elsewhere.
I am going to leave the warning to see if self clears eventually.
