VIN Numbers and relating possible issues to them
Grumpy
5:02 AM
Glasgow, UK
Hi,
As a new owner I was wondering whether there has been any comparison of VIN numbers and the potential issues that may be encountered.
We have just purchased a " newly" registered Fieldmaster that I assume was someone's previous order but never completed the transaction. As such it's registered as a "74" reg in Britain, although it has a VIN ending 03555 and a Build date of 25/05/23, collected 3 weeks ago with 10 miles on the odometer.
Issues encountered after 500 miles;
Wing mirror adjuster not working - Dealer sorted.
Passenger airbag fault light displayed - Dealer sorted, electrical glitch.
Tyre pressure warning sensor lighting for no reason - dealer suggested new and bedding in, settled down now.
AC initially poor hot and cold, then non existent - Dealer sorted suggesting air lock, refilled.
500 -1000miles
AC Leak,, substantial, into passenger footwell. - Booked into dealer in a fortnight, issue known? lagging issue?
Is this typical and should I expect more?
By the way, Grumpy has been a nickname for years nothing to do with the Grenny.
Love the new bus, its nearest thing we could find to replace our departed Amazon HDJ100.
G
My build is 11/2022 with Vin 00410, had it on my driveway 8/2023.
Except for the electronic glitches (Was solved with the software upgrade later) and a dead battery (because the vehicle was parked for months in Hambach after production - New battery under warrant)
Did a refill of the heater/cooler to solve the Heater/AC problem.
Since then no problems or issues anymore.
I have now almost 40K on the counter and he goes in next week for his second maintenance.
Remark, We have an (minor) oil leak on the front differential. Will also be dealt with next week during service under warrant.
So, that's it. I am a happy owner.
PS AC leak could also be condensation....
Are both your vehicles MY23/23.5? From what I have read on this forum, many of those models had similar issue. However, most issues got worked out with the MY24 models, which again I only found out on this forum, and the MY24 were the only models sent to the US. Makes sense as I have two and neither have given me any issues so far (other than the pesky speed warning & other beeps/sounds/warnings that hopefully will get fixed with the newest software update). 👍🙏
Mine is MY23. No ADAS or other systems.
Edit. Maybe even PRe-MY23. The build is from 11/22, the Dealer in Belgium was assigned in 2/23. The first Grenadier in the showroom was there 3/23. Sales and delivery's of the cars started 4? or 5/23
When I bought mine there were only some showroom models in place and maybe 10 sold cars on the terrain, waiting for delivery. That was 06/23
Mine would be a similar build time and my front diff is also leaking. They have replaced the yoke seal and when I last checked it was still leaking, will check again soon and chase them up.
Same, they replaced the joint I suppose, but were warning me that there still could drip grease off it. I guess when the diff is warm. I will keep my eye on it.
There were also some recall action, but all seems to be ok. And my auto Start/stop is working now.....
Am I right in thinking that shortly after VN 03555, <MY23.5, IG started adding in the ADAS systems?
"Toots" is off to Sterling next week to get her AC looked at along with the normal system as that's a bit hit and miss too. Not good with winter coming!
Also noticed we are sitting in low 70% - mid 60% on the battery SOC so looking like a new one will be requested.
Grumpy
Grumpy
No that's not right, my vin is 7601 and doesn't have ADAS. Built Oct 23, was built just before/same time as the production line for US production started with premium sound and ADAS
I can see i'll need a lot more input from others to try and get a meaningful narrative as to what happened when and what might or might not be a niggle.
More vins and build dates would be appreciated along with issues.
I see IG are starting to clear the stock, their website has now got access to stock which was previously the agents domain so more will be appearing out there on the streets. It still pretty unusual to see another up here on the roads though.
I see more Grens on the road these days. I would say in the last month I have seen 6 or 7 in my area of travels.
