Petrol/Gas US Oil for B58 Engines
5:24 AM
Denver, Co
Not yet. Just shy of 8k on the clock and going to do it at 10k with the diffs. Should be pretty simple in terms of process. Going to use Valvoline 75-90 Synthetic all the way around.
Fill the transfer case until it overflows the fill hole?
LWA55DAL
6:24 AM
San Antonio, TX, USA
Yes - that’s the same on the diffs. You want to do it cold as the oil will expand if it’s hot, but honestly - by the time you drain and fill - it won’t be that hot and your fine.
I personally overfill until it wants to keep coming out of the fill hole and plug it.
5:24 AM
Denver, Co
drained the transfer case today.. very easy. The fill and drain plugs are positioned well for easy access.
Opened the fill plug, and no fluid poured out. The drained oil had a lot of metal dust particles. I believe this is considered normal for a new transfer case going though break in period
LWA55DAL
6:24 AM
How many miles do you have? I am right at 8k so likely going to do it this weekend. Not shocking there were metal shavings. I have never seen a filter in a transfer case or axle. No pump to push it through the filter.
5:24 AM
Denver, Co
Under 1k on the odo
255/85
4:24 AM
Western U.S.
There are small filter screens and dedicated fluid pumps on many chain-drive transfer cases (NVG, etc) but they use lightweight ATF instead of gear oil. I've not seen a pump or filter in a gear drive 'case. If we knew the internal layout of the Tremec used in the Grenadier it might be possible to affix a powerful magnet to the exterior that would trap shavings against the inside wall.
Clark Kent
10:24 PM
Toowoomba QLD, Australia
Something is creating a positive flow to circulate the hot oil from the transfer case sump to the cooler in the LH wing and back to the top of the transfer case. I'll take a stab there's a small paddle pump in there somewhere.
LWA55DAL
6:24 AM
Forgot about that and very good point. It would not shock me to see an electric pump on the T case. Next time I am crawling around I’ll see if I can trace the lines. Should be simple to tell if it’s external or internal.
Now - there might be a temp valve in the system to also keep the temps at a constant level - lots of transmissions have that now but ATF fluid.
255/85
4:24 AM
Western U.S.
I don't remember seeing anything between the transfer and its dedicated radiator the last time I was under there but I wasn't looking for it either. The lines are pre-formed and look to be designed to handle some pressure which I thought was odd if it was somehow just passively circulating so an internal pump makes sense.
I was under the impression that the cooler was added fairly late in the development process to address overheating issues seen in real world testing. I probably read that somewhere here so it could have been conjecture back when everyone was theorizing.
LWA55DAL
6:24 AM
Ok - just did the diffs at just over 8k Miles and the oil was filthy. I should have taken pictures, but was trying to just get it done late this evening. Generally speaking - it looked equivalent to what I would expect to see out of vehicle with 40+k Miles. Lots of small metallic metal shavings floating around. The drain and fill plugs both have small magnets - much smaller than what you see on a Toyota and the magnets were covered - both the fill and drain. I did run it pretty hard before doing the job to try and warm up the diffs and they were warm to the touch when I did the oil change. I could even see reflections in the light when I filled them up coming out of the fill hole (metal in the new oil flowing out). If you are considering it - its a VERY easy job, but I was a little shocked at how bad the oil was and I now completely understand the service internal of 12k Miles.
I am planning on doing in the T-case next weekend and will report back.
I will note that I have the lockers and I have cycled them well over 100+ times to try and get them “broken-in”. At 1st - they were hard to actuate, but now they work almost instantly. I have also driven well over 100 miles “locked” so that puts more stress on the diffs and is likely correlated to what I saw in the oil.
LWA55DAL
6:24 AM
The t case fill and drain plugs are not magnetic.
Curious - how much oil did the T-case take? I hadn’t thought about the cooler and trying to think through the total capacity of the T-case and cooler. The cooler is certainly higher than the T-case so unless there is a back-flow valve - filling the T-case to the fill line won’t re-fill the cooler and the T-case will be low.
Michael_in_Baja
4:24 AM
Baja California Sur, Mexico
Thank you for this. I thought the differential service at 12,000 miles might have been excessive but apparently not. I will do mine with my second oil change at 5,000 miles.
LWA55DAL
6:24 AM
Worth noting - I pulled the fill plugs 1st and neither of them had oil seeping out. I put a finger in the hole and I could not touch oil with either them further supporting the idea that they are not properly filled at the factory as I have read on a couple of the posts. I would say they were every bit of 1-2CM low - maybe more as I could not feel anything and this was on hot diffs so the oil should be at max level at that point.
Regardless of mileaage - worth checking the fill level. No leaks of any kind at the diffs, but not where they should be on a factory fill.
LWA55DAL
6:24 AM
Most diffs do not call for an oil change until 30+k miles, but these are tractor axles. Look at any tractor manual and they all call for diff changes after break-in around 200 hours. The axles, diffs and lockers are more like a tractor than a typical car these days so it makes sense. Per the manual the next diff change is around 35k or so, but I am likely going to do it after the next 10k and at least see what it looks like.
