(Urgent) Oil leak on the upper right side of the driver's seat
Grenadian
12:12 PM
Korea
Hello? Members, I received the car on October 23rd.
It has now driven 1700 km. However, oil is leaking from the top of the accelerator.
It does not happen always, and this is the second time since the first day.
I do not know if there is a rule. The driver's seat position is the same as in the United States, left-hand drive.
1. It is not the washer fluid. Because today is a clear day, I did not use washer fluid.
2. It has a sticky viscosity, smells sweet, and is clear and transparent.
3. If you look at the picture, it sprays from top to bottom as if there is pressure. It is not one or two drops compared to an hour of driving, but a large amount.
4. Even if I turn the steering wheel all the way to the left and right and press the accelerator at about 3000 rpm, the oil does not leak out.
5. If you look at the upper left of the photo, you can see a black sponge? The lower right part of this sponge is soaked.
** Is it possible that the leak occurred while the car was parked?
What kind of oil would pass through the upper part of the accelerator?
Eric
3:12 AM
Scotland
Possibly air con leak, or heater matrix
anand
10:12 PM
Maryland
There is no oil in that area. The only fluids that comes into the vehicle is A/C refrigerant or engine coolant. Coolant would be very hot
That certainly looks like the A/C condenser water drip, which is fairly common, especially if it is humid.
Here's the technical service bulletin for the repair. As stated above, it is a 6-9 hour service that involves removing the dash
Grenadian
12:12 PM
Korea
There is no oil in that area. The only fluid that comes into the vehicle is A/C refrigerant.
When I touched it, it wasn't the water type. It was definitely the oil type.
anand
10:12 PM
Maryland
Is glycol clear? I wiped it with a tissue and it was colorless and clear.
If it was coolant/glycol it would generally dry to be a crusty pink
3:12 AM
PAG oil in the a/c gas circulates through the entire system. It can separate and drip from a leak at a joint or fine cracks. A/C oil can come in various colours green yellow colour if it has had uv dye in the system. A/c gas can have a gas smell to an acid smell. It can also be coolant leaking from the heater core or connections. In Australia coolant has a bittering agent by law so it's not sweet this is not the case in all countries. Coolant that drys hot will leave a crusty off white trail if it is flowing it will remain the colour of the coolant. Undiluted coolant is slippery like oil and can slightly separate from the water in slow cold leaks that go away at operating temperature.
