Uprated suspension springs
James Cox
9:10 PM
Wiltshire, UK
Good evening all! I have a 2 seat utility which is boxed out to carry tools and parts as a service vehicle. With me sat in it on a weigh bridge it is 3440kgs, so 60 kgs off max. Weight. It drives and carries the weight well, but does sit a bit lower at the rear. I want some uprated rear springs to get it back up to normal kerb height, but not sure where to source in the uk? The dealer has suggested aftermarket rather than through Ineos….
Reactions: Max
Is the Eibach lift kit available in the UK? It is in the US and Australia. In Australia now you can three different spring ratings (Standard, Heavy Duty and Extra Heavy Duty). The Eibachs come out of Germany.
I'd suggest the Eibachs are too low of spring rate. We really need a source for some HD springs.
Reactions: Max
Somewhere I saw the ozzys have a nice in cab adjustable airbag kit. I’ve used airbags in class 4 roads with success much to my surprise. Don’t see why they would work well in this application.
He can look at item 4, 5 (air bags) and 11 (adjustable). And I think MORE4x4 may have one also.
SUSPENSION FOR THE GRENADIER
  1. Eibach 35mm Pro Lift Kit, look here (Standard, Heavy Duty and Extra Heavy Duty springs available);
  2. Eibach 35mm Pro lift kit/King Shocks package, look here;
  3. King Shocks Set (4), look here;
  4. GrenX has a full suspension upgrade solution using Eibach springs, custom Bilstein shocks, Bilstein steering damper & rear air bags by Poly Air, look here;
  5. AIRBAG MAN suspension for the INEOS Grenadier here;
  6. Dobinson lift kit under development, look here;
  7. SOLVE Offroad using Fox shocks and Eibach springs. Review here by @Braydo;
  8. LeTech Suspension system lift + 40mm (nearly AUD15,000);
  9. LeTech coil springs +40mm;
  10. Oleo-Pneumatic suspension for the INEOS Grenadier, shipped from France;
  11. JMACX manual adjustment suspension kit here. Also with INEOS ANZ, look here. You will need to contact JMACX by phone or email;
  12. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITH winch;
  13. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITHOUT winch; AND
  14. Some US suspension options being discussed here.
The Extra Heavy Duty (XHD) Eibach springs – Minimum constant load 300kg, are pretty beefie...is it ball weight or just a constant load you are concerned about?
I have just ordered my Eibachs after discussing the pros and cons with the service bloke at XHQ, because of my type of typical driving and towing weights the standard will be fine because they are already a stronger rated spring. They are the same height as the originals but the vehicles height gain is due to less sag and I won't have to wear a kidney belt :)
I would be cautious about using lifted (longer) heavy duty springs, even from Eibach. The failure rate of front driveshafts is anecdotally higher in lifted vehicles than standard height vehicles.
Given you're only seeking an increased spring rate I would avoid a lift kit - at least until the driveshaft CV failure mode is better understood.
If you fit a set of heavier springs from the factory options (chart below) your warranty should be unaffected. See what colour code springs you already have fitted. You may be able to upgrade to heavier rears. Black triangles is the highest rear spring rate available from the factory.
If your load is constant then upgrade the springs. If you occasionally run at higher weights then rear load assist airbags would be a good choice to restore the lost ride height due to spring sag without living with a stiffer ride at lower weights.
I agree...The failures are the big lifts, mainly USA...These springs are designed for the Grenadier and they are not longer just beefed up to stop sag 40mm front and 35mm rear? it is not a big lift so to speak. Eibachs at XHQ Australia
Agreed, rate and lift are not the same, BUT keep in mind, the rate is designed to be the same ride height with the 200+ lbs/kg/stone or wtf ever you are rating, and if that mass isn't there, you will still have a lift, just a shitty stiff riding lift. Hence, I'd be on the adjustable air bags. It's a poor mans hydraulic, and it works.
Reactions: Max
How reliable/long lasting are suspension airbags. They do seem a good idea for loaded vehicles
Reactions: Max
I personally went with the Airbagman airbags, absolutely perfect for the application you describe..
Reactions: Max
The longest Airbag have seen is a set that lasted 20 years.
I guess it depends on the maker. I had firestones on for a couple years and never had an issue, and I was flexing the hell out of the Lc100 suspension with about 2" lift and 35's.
I would go airbags. That's what I plan to do - likely airbag man with manual inflate using a Schrader valve.
You get the best of all worlds - comfortable, stock ride when not loaded and airbags are low pressure at 5lbs or so, and then reduced squat to stay off the bump stops and firmer ride when laden and springs are at pressure, which can be adjusted dynamically / dialed in based on load.
I self-installed and ran Airbags in my 2500 pickup truck when I had an extra 1,500 lbs on the rear axle when towing / loaded it was perfect. I plan to tow an airstream again at or just above rear axle rating and will use them to level and firm things up when trailer is attached.
Reactions: Max
I installed the Airbag Man high pressure kit yesterday. Because of my load, the suspension was always resting on the end stop buffer.
Now I raise it 2-3 cm below the original unloaded spring height.
Nevertheless, I can't get the fear out of the head of the front drive shaft being damaged, or do I now improve the angle of the front drive shaft since I only raise it slightly at the back. But just below the normal unloaded height?
Hope the translator makes it understandable.
Reactions: Max
Airbags are also an option as they all that is needed (suspension only) for the 4T GVM upgrade.
Are there any uk suppliers for airbags?
Also would be interested to assist occasional towing.
G
I would think about HD Eibach springs if you are constantly carrying that weight. That way you will be able to drive in the normal height range and reduce stress on the bags and shocks (y)
Yep. That's good advice @Max . HD springs are also referred to as constant load springs for that reason.
Reactions: Max
