- Local time
- 4:20 AM
- Joined
- Jan 24, 2024
- Messages
- 55
- Reaction score
- 104
- Location
- Alpine Meadows/Redwood Shores, CA
I received the transfer case skid last Monday and just installed it this afternoon. It’s much better packed than the engine/transmission skid. Installation was easy, with most time spent fiddling with the insert nuts like Nadir said. The wire is just barely long enough for the cross member holes on the driver side. A couple tips: thread the bolt on and off the inserts a few times before inserting them to make it easier for the bolt to start. For the one on the chassis, I used a needle nose plier to hold the flat leads through the opposite hole. Instructions weren’t clear on this, but I also removed (temporarily) the seal that covers the hole on the other side.
Is the purpose of the additional small skid to protect fuel lines? From pictures it looks like there is a filter or something there, but perhaps it’s only for the B37.
The skid does sit quite low. Not lower than the fuel tank guard but it sits lower than the factory sliders.
