I started a 5-tire rotation last night and thought I’d share my experience so far in hopes of helping others who also want to perform rotations themselves.
I followed the method several others have used where you swap out one corner with the spare, keeping the extra tire mounted in on the rear door, then drive around for a few miles before returning to repeat the process 3 times.
I set the front tires to 35psi, rear to 40psi and the spare to 50psi and followed the below pattern.
There are 4 steps:
1 - Swap RR with the spare
2 - Swap FR with the spare
3 - Swap RL with the spare
4 - Swap FL with the spare
I made 5 diagrams, labeled the tires 1 through 5 based on their original position and marked the PSI. That way I can tell what the pressure should be on all 4 corners based on why step I’m on.
Last night I completed step #1 and went for a drive with the off-road temperature/pressure display pulled up. After about 4-5 miles the rear right display updated from 41psi to 52psi, indicating it recognized the original spare (tire #5) had been moved to the RR position. Simple as that. I then completed #2, but being New Years Eve didn’t have time to take it for a drive again.
While this isn’t the easiest 5-tire rotation process, I’m encouraged that I could easily complete this in an afternoon or over a few days if I wanted to do one corner per day after work until completed. For me, this is better than paying a dealer to perform it and also better than buying new sensors and a tool to update the positions. Trying to keep this “simple” vehicle as simple as possible and not add special tools if they aren’t necessary.
Once I complete the process I’ll report back with any further findings.
